RAL access stuck and not executed
In reply to mitesh.patel:
Hi, basically this is the flow (also driver code is below):
  • reg1.write() issued
  • reg2bus() done, Driver gets transaction from Sequencer
  • reg1.is_busy() = 1 (this register becomes busy)
  • trans starts on the bus
  • trans ends on the bus, Driver calls end_tr() and item_done(), waiting for new transaction from Sequencer
  • reg1.is_busy() = 0
  • after some time
  • new reg2.read() issued
  • reg2bus() done
  • reg2.is_busy() = 1 (this register becomes busy)
  • Driver never gets transaction from the Sequencer
  • reg2.is_busy() = 1 remains forever
    m_req=new();
    m_req.enable_recording(“drv_item”);
    void’(this.begin_tr(m_req,“sent_items”));
    this.end_tr(m_req);
    // Drive initial signal values to IF
    // Call main driving task
    do_access();
    endtask: run_phase
    task do_access();
    forever begin
    uvm_info(get_type_name(), $sformatf("Wait a transaction from sequencer"), UVM_LOW); seq_item_port.get_next_item(m_req); uvm_info(get_type_name(), $sformatf(“Got a transaction from sequencer, wait mbox_full=0”), UVM_LOW);
          // Wait some condition
          while (...) @(posedge clk);
          `uvm_info(get_type_name(), $sformatf("Driving a transaction: %s\n", m_req.sprint()), UVM_LOW);
          void'(this.begin_tr(m_req,"sent_items"));
          // Drive signals to IF
          // Wait some small delay
          `uvm_info(get_type_name(), $sformatf("Ending a transaction"), UVM_LOW);
          this.end_tr(m_req);
          seq_item_port.item_done();
          `uvm_info(get_type_name(), $sformatf("Emit item_done()"), UVM_LOW);
    endtask: do_access
