Race between procedural Blocks and always block triggering itself
module test;
  task foo (ref bit[3:0] a1, ref bit[3:0] out_a3);
  $display(“[task]Start of TAsk a1= %d at time = %0t”,a1, $time);
  #2 a1=5;
  $display(“[task] al changed to=%0d at time=%0t”,a1, $time);
  #2 out_a3 = a1+3;
  #1
  $display (“Ltask End of task al=%0d out_a3=%0d at time-%0t”, a1, out_a3, $time);
//end of time 7
bit [3:0] i1, out;
  i1=0; out=0;
  foo(i1,out);
  $display("[test] i1=%0d out=%0d at time=%0t ",i1,out,$time);
 always @(i1) begin
    $display(“[Always_i1] Detected change on i1=%0d at time=%0t”, i1,$time);
    i1++;
  always @(out)
    $display(“[Always_out]Detected change on out=%0d at time=%0t”, out, $time);
From the above code we are getting output as below :
[task]Start of TAsk a1=  0 at time = 0
[task] al changed to=5 at time=2
[Always_i1] Detected change on i1=5 at time=2
[Always_out]Detected change on out=9 at time=4
Ltask End of task al=6 out_a3=9 at time-5
[test] i1=6 out=9 at time=5
My question here is when we got enter to the always blk we can’t struck there contionously as i incrementing (i++), And is there any race happening between all procedural blks and why compiler not triggering always blk when we intialize i1 with 0.
This post should explain how event controls interact with procedural blocks.
Since you declared i1 as a bit, its value is already 0. Assigning it to 0 doesn’t change its value. Even if you assigned it to 1, there’s a race condition because the procedural block might not see the change.
Thank you So much @dave_59 , I got clarified
