Question on use of RAL model for System-On-Chip verification
I have a question concerning use of RAL model for system-on-chip (SOC) verification. My understanding is that RAL model is used mainly for IP based verification where IP exposes one of the interfaces such as AHB, APB or AXI lite through which internal registers (for control/configuration, monitoring etc) can be accessed. For SOC based verification in which SOC uses ARM cores and high speed peripherals connected through an AXI interconnect, we do not use/cannot use RAL model but registers are accessed in simulation by writing C language test cases which would run on one of the ARM cores. The register test cases would perform read/writes of all the registers of all peripherals connected on AXI interconnect and verify if they can be read/written correctly using different patterns. These test cases would also check for Read only (RO), read/write (R/W), Write clear, read clear etc operation of the bits of all the registers. Is this understanding correct?
Our customer is expecting us to write register based sequences for register read/write test cases, which we find strange and difficult to understand.
Can someone elaborate please?
thanks and regards,
-sunil
There are several different approaches you can use.
  • Replace the CPU core with a BFM based model. This allows you to utilize the RAL to do register testing using sequences instead of writing C language tests.
  • Utilize bus agents as monitors and use the RAL as a checker for register accesses.
Thanks for the reply. However, none of the busses which are used for register access (APB) are exposed on SOC interface. THey are just giving us SOC RTL in encoded form.
regards,
-sunil
Also using the RAL model for checking may not check the internal data paths of SOC.
If you are being provided RTL in encrypted form, then it should be up to the IP provider to ensure that verification is completed. There is no way for a user to conduct effective verification on encrypted IP.
