Hi Forum,
(1) 18.5.9 Variable ordering from SV LRM-2023 mentions
Variables may be solved in an order that is not consistent with the ordering constraints,
provided that the outcome is the same.
An example situation where this might occur is as follows:
x == 0;
x < y;
solve y before x;
In this case, because x has only one possible assignment (0), x can be solved for before y.
The constraint solver can use this flexibility to speed up the solving process.
(Q1) Given that all constraints are solved in parallel to form a solution space and then any of the solution is chosen, why does the LRM say that x can be solved before y ?
(2) 18.11.1 Inline constraint checker mentions
Normally, calling the randomize() method of a class that has no random variables causes the method to behave as a checker.
In other words, it assigns no random values and only returns a status: 1 if all constraints are satisfied and 0 otherwise.
For an empty class declaration
class Empty;
// No random variables nor any constraint
Empty emp = new()
if( emp.randomize() ) $display(“Pass“);
(Q2) As there is nothing to randomize or to check (via constraint),why is randomization successful ?
Thanks in Advance
