In reply to shreebamnikar:
Yes, provided you use field macros, see an example below:
class vl_data extends uvm_reg;
`uvm_object_utils(vl_data)
rand uvm_reg_field data;
// More code below
endclass : vl_data
// vl_ctrl
class vl_ctrl extends uvm_reg;
`uvm_object_utils(vl_ctrl)
rand uvm_reg_field ctrl;
// More code below
endclass : vl_ctrl
task vlb_reg_model_test::main_phase(uvm_phase phase);
int res;
phase.raise_objection(this);
`uvm_info(get_name(),
$sformatf("Printing REG model "),UVM_LOW)
this.vlb_reg_block_1 = vlb_reg_block::type_id::create("vlb_reg_block_1");
this.vlb_reg_block_1.build();
this.vlb_reg_block_1.print();
Output:
# : Name Type Size Value
# : vlb_reg_block_1 vlb_reg_block - @818
# : vl_data vl_data - @820
# : data uvm_reg_field ... RW vl_data[31:0]=32'h00000000
# : vl_ctrl vl_ctrl - @824
# : ctrl uvm_reg_field ... RW vl_ctrl[31:0]=32'h00000000
# : vl_volatile vl_volatile - @828
# : cntr uvm_reg_field ... RO vl_volatile[31:0]=32'h00000000
# : vlb_map uvm_reg_map - @832
# : endian ... UVM_LITTLE_ENDIAN
# : vl_data vl_data ... @820 +'h8
# : vl_ctrl vl_ctrl ... @824 +'hc
# : vl_volatile vl_volatile ... @828 +'h4
HTH
Srini
www.go2uvm.org
