Performance Degrade when calling sequencer ".start" repeatedly
Hey,
My simulation runs super-slow when I toggle interface lines with UVM based methods versus using Xilinx verilog IP to toggle the lines.
I attached the code I think is relevant below (some code was removed for easier reading).
Following the profiling process (in the two photos attached), it seems like “.start” method in uvm_sequence_base.svh, which I call a lot of times, causes that degrade (very high usage of stack).
I use Questa 2020.4 as my simulator.
Thanks.
typedef uvm_sequence #(uvm_sequence_item) uvm_virtual_sequence;
class VirtualSequence extends uvm_virtual_sequence;
	`uvm_object_utils(VirtualSequence)
	typedef AxiStreamMasterBaseSequence#(AXI_STREAM_DATA_WIDTH_IN) AxiStreamMasterBaseSeq;
	typedef AxiStreamSlaveBaseSequence#(AXI_STREAM_DATA_WIDTH_OUT) AxiStreamSlaveBaseSeq;
	typedef axi_lite_item #(AXI_LITE_ADDR_WIDTH,AXI_LITE_DATA_WIDTH) axi_lite_item_t;
	operation_t axiLiteOp;
	MemoryConfig memConfig;
	GenericHandlers genericHandlers;
	rand frameBufferOps frameBufferOp;
	rand int camIDPressure;
	int camID;
	int lineCount;
	virtual AxiStreamIf#(AXI_STREAM_DATA_WIDTH_OUT) axiStreamMasterVif;
	AxiStreamSlaveSanitySequence#(AXI_STREAM_DATA_WIDTH_OUT) axiStreamSlaveSanitySeq;
	AxiStreamSlaveNormalSequence#(AXI_STREAM_DATA_WIDTH_OUT) axiStreamSlaveNormalSeq;
	AxiStreamMasterSanitySequence#(AXI_STREAM_DATA_WIDTH_OUT) axiStreamMasterSanitySeq;
	AxiStreamMasterValidReadyRandomSequence#(AXI_STREAM_DATA_WIDTH_OUT) axiStreamMasterValidReadyRandomSeq;
	AxiStreamMasterDropValidSequence#(AXI_STREAM_DATA_WIDTH_OUT) axiStreamMasterDropValidSeq;
	AxiStreamMasterResetSequence#(AXI_STREAM_DATA_WIDTH_OUT) axiStreamMasterResetSeq;
	AxiStreamMasterFullRandomSequence#(AXI_STREAM_DATA_WIDTH_OUT) axiStreamMasterFullRandomSeq;
	AxiLiteGenericSequence#(AXI_LITE_ADDR_WIDTH, AXI_LITE_DATA_WIDTH) axiLiteWrSequence;
	AxiLiteGenericSequence#(AXI_LITE_ADDR_WIDTH, AXI_LITE_DATA_WIDTH) axiLiteRdSequence;
	FrameBufferEnvConfig frameBufferEnvCfg;
	uvm_sequencer#(axi_lite_item_t) axiLiteSeqrTPG;
	uvm_sequencer#(axi_lite_item_t) axiLiteSeqrDUT;
	uvm_sequencer#(AxiStreamSequenceItem#(AXI_STREAM_DATA_WIDTH_OUT)) axiStreamMasterSeqr;
	uvm_sequencer#(AxiStreamSequenceItem#(AXI_STREAM_DATA_WIDTH_OUT)) axiStreamSlaveSeqr;
	uvm_sequencer#(AxiStreamSequenceItem#(AXI_STREAM_DATA_WIDTH_OUT)) resetSeqr;
	uvm_event MemoryConfigUpdated;
	uvm_event resetEvent;
	bit[7:0] backgroundPattern;
	extern function new(string name="VirtualSequence");
	extern function void createSequenceObjects();
	extern function void initAndUpdateReset();
	extern function logic[AXI_STREAM_DATA_WIDTH_OUT-1:0] getNextData();
	extern task sanity();
	extern task setTuser(AxiStreamMasterBaseSeq axiMasterSeq, AxiStreamSlaveBaseSeq axiSlaveSeq);
	extern task resetDUT();
	extern task triggerReset();
	extern task fullRandom(sofE isSOF = SOF_ENABLE);
	extern task transmitPixels(AxiStreamMasterBaseSeq axiMasterSeq1, AxiStreamMasterBaseSeq axiMasterSeq2, AxiStreamSlaveBaseSeq axiSlaveSeq1, AxiStreamSlaveBaseSeq axiSlaveSeq2);
	extern task startAxiLiteSequence(uvm_sequencer#(axi_lite_item_t) axiSeqr, AxiLiteGenericSequence#(AXI_LITE_ADDR_WIDTH, AXI_LITE_DATA_WIDTH) axiSeq, logic[31:0] address, logic[31:0] data, operation_t op);
	extern task startSlaveSequence(uvm_sequencer#(AxiStreamSequenceItem#(AXI_STREAM_DATA_WIDTH_OUT)) slaveSeqr, AxiStreamSlaveBaseSeq slaveSeq, logic tready = 1'bz);
	extern task startMasterSequence(uvm_sequencer#(AxiStreamSequenceItem#(AXI_STREAM_DATA_WIDTH_OUT)) masterSeqr, AxiStreamMasterBaseSeq masterSeq, logic tuser = 1'bz, logic tvalid = 1'bz, logic tlast = 1'bz, logic[AXI_STREAM_DATA_WIDTH_OUT-1:0] tdata = {AXI_STREAM_DATA_WIDTH_OUT{1'bz}}, logic reset = 1'bz, bit takeNewData = 1'b1);
	extern virtual task body();
endclass : VirtualSequence
function VirtualSequence::new(string name="VirtualSequence");
	super.new(name);
function void VirtualSequence::createSequenceObjects();
	axiLiteWrSequence = AxiLiteGenericSequence#(AXI_LITE_ADDR_WIDTH, AXI_LITE_DATA_WIDTH)::type_id::create("axiLiteWrSequence");
	axiStreamSlaveSanitySeq = AxiStreamSlaveSanitySequence#(AXI_STREAM_DATA_WIDTH_OUT)::type_id::create("axiStreamSlaveSanitySeq");
	axiStreamSlaveNormalSeq = AxiStreamSlaveNormalSequence#(AXI_STREAM_DATA_WIDTH_OUT)::type_id::create("axiStreamSlaveNormalSeq");
	axiStreamMasterDropValidSeq = AxiStreamMasterDropValidSequence#(AXI_STREAM_DATA_WIDTH_OUT)::type_id::create("axiStreamMasterDropValidSeq");
	axiStreamMasterSanitySeq = AxiStreamMasterSanitySequence#(AXI_STREAM_DATA_WIDTH_OUT)::type_id::create("axiStreamMasterSanitySeq");
	axiStreamMasterValidReadyRandomSeq = AxiStreamMasterValidReadyRandomSequence#(AXI_STREAM_DATA_WIDTH_OUT)::type_id::create("axiStreamMasterValidReadyRandomSeq");
	axiStreamMasterResetSeq = AxiStreamMasterResetSequence#(AXI_STREAM_DATA_WIDTH_OUT)::type_id::create("axiStreamMasterResetSeq");
	axiStreamMasterFullRandomSeq = AxiStreamMasterFullRandomSequence#(AXI_STREAM_DATA_WIDTH_OUT)::type_id::create("axiStreamMasterFullRandomSeq");
function logic[AXI_STREAM_DATA_WIDTH_OUT-1:0] VirtualSequence::getNextData();
	return $urandom_range(0,INPUT_MAX_VAL);
task VirtualSequence::startSlaveSequence(uvm_sequencer#(AxiStreamSequenceItem#(AXI_STREAM_DATA_WIDTH_OUT)) slaveSeqr, AxiStreamSlaveBaseSeq slaveSeq, logic tready = 1'bz);
 	if (tready !== 1'bz)
 		slaveSeq.tready = tready;
	slaveSeq.start(slaveSeqr);
task VirtualSequence::startMasterSequence(uvm_sequencer#(AxiStreamSequenceItem#(AXI_STREAM_DATA_WIDTH_OUT)) masterSeqr, AxiStreamMasterBaseSeq masterSeq, logic tuser = 1'bz, logic tvalid = 1'bz, logic tlast = 1'bz, logic[AXI_STREAM_DATA_WIDTH_OUT-1:0] tdata = {AXI_STREAM_DATA_WIDTH_OUT{1'bz}}, logic reset = 1'bz, bit takeNewData = 1'b1);
 	if (reset !== 1'bz)
 		masterSeq.reset = reset;
 	if (tuser !== 1'bz)
 		masterSeq.tuser = tuser;
 	if (tvalid !== 1'bz)
 		masterSeq.tvalid = tvalid;
 	if (tlast !== 1'bz)
 		masterSeq.tlast = tlast;
	masterSeq.start(masterSeqr);
task VirtualSequence::transmitPixels(AxiStreamMasterBaseSeq axiMasterSeq1, AxiStreamMasterBaseSeq axiMasterSeq2, AxiStreamSlaveBaseSeq axiSlaveSeq1, AxiStreamSlaveBaseSeq axiSlaveSeq2);
	while(!axiStreamMasterVif.tlast) begin
				startMasterSequence(axiStreamMasterSeqr, axiMasterSeq1, 0);
				startSlaveSequence(axiStreamSlaveSeqr, axiSlaveSeq1);
		join
		if (frameBufferEnvCfg.axiStreamMasterCfg[camID].disableEOL && axiStreamMasterVif.pixelCounterOut % IMG_WIDTH == 0 && axiStreamMasterVif.pixelCounterOut != 0) begin
			lineCount++;
			if (lineCount == IMG_HEIGHT) begin
				return;
	lineCount++;
	while (axiStreamMasterVif.tlast) begin
				startMasterSequence(axiStreamMasterSeqr, axiMasterSeq2, 0);
				if (lineCount >= IMG_HEIGHT-1)
					startSlaveSequence(axiStreamSlaveSeqr, axiStreamSlaveSanitySeq);
					startSlaveSequence(axiStreamSlaveSeqr, axiSlaveSeq2);
		join
endtask : transmitPixels
task VirtualSequence::setTuser(AxiStreamMasterBaseSeq axiMasterSeq, AxiStreamSlaveBaseSeq axiSlaveSeq);
			startSlaveSequence(axiStreamSlaveSeqr, axiSlaveSeq);
			startMasterSequence(axiStreamMasterSeqr, axiMasterSeq, 1, 1);
	join
function void VirtualSequence::initAndUpdateReset();
	lineCount = 0;
	genericHandlers.finishedRandomizingMemConfig = 0;
endfunction : initAndUpdateReset
task VirtualSequence::sanity();
	int lineCount;
	// Raise tready
	axiStreamMasterVif.clockingBlock.tdata <= getNextData();
	//Set tuser, tvalid
	startMasterSequence(axiStreamMasterSeqr, axiStreamMasterSanitySeq, 1, 1);
	// transmit IMG_HEIGHT lines with IMG_WIDTH pixels per line
	repeat(IMG_HEIGHT) begin
		transmitPixels(axiStreamMasterSanitySeq, axiStreamMasterSanitySeq, axiStreamSlaveSanitySeq, axiStreamSlaveSanitySeq);
	//drop valid at end of frame
	startMasterSequence(axiStreamMasterSeqr, axiStreamMasterDropValidSeq, 1'b0, 1'b0, 1'b0,{ParametersPkg::AXI_STREAM_DATA_WIDTH_OUT{1'bz}}, 1'bz, 1'b0);
	lineCount = 0;
endtask : sanity
task VirtualSequence::fullRandom(sofE isSOF = SOF_ENABLE);
	int resetLine;
	bit isReset;
	// randomize if there is reset in this frame
	void'(std::randomize(isReset) with {isReset dist{0:= 8, 1:=2};});
	//randomize the line in which reset will be activated if isReset=1
	void'(std::randomize(resetLine) with {resetLine inside{[1:IMG_HEIGHT-1]};});
	//decide whether to activate SOF or not
	if (isSOF != SOF_DISABLE) begin
		setTuser(axiStreamMasterValidReadyRandomSeq, axiStreamSlaveNormalSeq);
 	repeat (IMG_HEIGHT) begin
		transmitPixels(axiStreamMasterValidReadyRandomSeq, axiStreamMasterValidReadyRandomSeq, axiStreamSlaveNormalSeq, axiStreamSlaveNormalSeq);
		if (isReset && camID == 0) begin
			if (lineCount == resetLine) begin
				resetDUT();
		 		break;
	startMasterSequence(axiStreamMasterSeqr, axiStreamMasterDropValidSeq, 1'b0, 1'b0, 1'b0,{AXI_STREAM_DATA_WIDTH_OUT{1'bz}}, 1'bz, 1'b0);
	lineCount = 0;
task VirtualSequence::triggerReset();
		forever @(posedge axiStreamMasterVif.clk) begin
			if (!axiStreamMasterVif.reset)
				resetEvent.trigger();
	join_none
endtask : triggerReset
task VirtualSequence::resetDUT();
	startMasterSequence(resetSeqr, axiStreamMasterResetSeq, , 0, 0);
	`uvm_info(get_type_name(), "resetting DUT...", UVM_LOW)
		// re-transmit frame, openImageFile() will open the same file for re-transmission
	axiStreamMasterSeqr.stop_sequences();
	axiStreamSlaveSeqr.stop_sequences();
endtask : resetDUT
task VirtualSequence::body();
	int randomDelayBetweenFrames;
	if(!uvm_config_db #(virtual AxiStreamIf#(AXI_STREAM_DATA_WIDTH_OUT))::get(.cntxt(null), .inst_name(""), .field_name($sformatf("axiStreamMasterVif_%0d", camID)), .value(axiStreamMasterVif))) begin
    	`uvm_fatal(get_name(), "NO VIF::interface not found")
	resetEvent = uvm_event_pool::get_global("resetEvent");
	triggerReset();
	configDUT();
	wait(axiStreamMasterVif.reset);
	case (frameBufferOp)
		USE_TPG : begin
			`uvm_info(get_type_name(), $sformatf("Running operation %0s..", frameBufferOp.name()), UVM_LOW)
			configAndStartTestPatternGenerator();
		RANDOM_AXI_STREAM : begin
			repeat(13) begin
				fullRandom();
				void'(std::randomize(randomDelayBetweenFrames) with {randomDelayBetweenFrames inside {[10:100]};});
				repeat(randomDelayBetweenFrames) @(posedge axiStreamMasterVif.clk);
	endcase
endtask : body
class AxiStreamMasterBaseSequence#(parameter DATA_WIDTH) extends uvm_sequence #(AxiStreamSequenceItem#(DATA_WIDTH));
	`uvm_object_param_utils(AxiStreamMasterBaseSequence#(DATA_WIDTH))
	//Environment Config
	AxiStreamSequenceItem#(DATA_WIDTH) req;
	bit tuser;
	bit tvalid;
	bit tready;
	bit tlast;
	bit reset;
	bit imageFromFile;
	logic[DATA_WIDTH-1:0] tdata;
	function new(string name="AxiStreamMasterBaseSequence");
		super.new(name);
		req = AxiStreamSequenceItem#(DATA_WIDTH)::type_id::create("req");
	task body();
	bit tuser;
	bit tvalid;
	bit tready;
	bit tlast;
	bit reset;
	bit imageFromFile;
		super.new(name);
	task body();
class AxiStreamMasterFullRandomSequence#(parameter DATA_WIDTH) extends AxiStreamMasterBaseSequence#(DATA_WIDTH);
	`uvm_object_param_utils(AxiStreamMasterFullRandomSequence#(DATA_WIDTH))
	function new(string name="AxiStreamMasterFullRandomSequence");
		super.new(name);
	task body();
		super.body();
		start_item(req);
		//`uvm_info(get_type_name(), $psprintf("body started"), UVM_DEBUG)
		if (imageFromFile) begin
			req.tdata.rand_mode(0);
			req.tdata = this.tdata;
		void'(std::randomize(reset) with {reset dist {0:=1, 1:=10000};});
		if(!req.randomize() with {
				req.tvalid dist {1:=99, 0:=1};
				req.tvalidNumOfCyclesDelay inside {[0:2]};
				req.tuser == local::tuser;
				req.tlast == local::tlast;
				req.reset == local::reset;
				(req.reset == 0) -> req.resetNumOfCyclesDelay inside {[50:100]};
			})	`uvm_fatal(get_type_name(), "inline randomization error")
		finish_item(req);
		//`uvm_info(get_type_name(), $psprintf("body finished"), UVM_DEBUG)
class AxiStreamSlaveNormalSequence#(parameter DATA_WIDTH) extends AxiStreamSlaveBaseSequence#(DATA_WIDTH);
	`uvm_object_param_utils(AxiStreamSlaveNormalSequence#(DATA_WIDTH))
	bit treadySwitch;
	function new(string name="AxiStreamSlaveNormalSequence");
		super.new(name);
	task body();
		super.body();
		start_item(req);
		if (treadySwitch) begin
			req.tready = 1;
		else begin
			// Only tready is interesting here
			if(!(req.randomize() with {
					req.treadyNumOfCyclesDelay inside {[0:2]};
					req.tready dist {1:=95, 0:=5};
				}))	`uvm_fatal(get_type_name(), "inline randomization error")
		treadySwitch = (req.tready == 0) ? 1 : 0;
		finish_item(req);
Although your problem might not be tool specific, debugging it might be. You may need to contact your vendor for guidance. This forum is not for discussion of tool specific usage or problems.
There is nothing in the code shown that indicates an issue. But we don’t have all the code to run and re-create the problem. Also, we would need to see what you are comparing it to. Are there any differences in randomization that could make this appear to be a problem (i.e. the length and size of transactions)?
I don’t think it is tool specific either. specified that merely for completion of details.
What i’m comparing it to is an IP provided by xilinx, generated in Vivado tpg which toggles axi-stream lines instead of me.
I’m attaching the axi-stream driver and monitor code as well.
class AxiStreamSequenceItem#(parameter DATA_WIDTH) extends uvm_sequence_item;
	rand logic reset;
	rand logic tready;
	rand logic tvalid;
	rand logic tuser;
	rand logic tlast;
	rand logic [DATA_WIDTH-1:0] tdata;
	rand int treadyNumOfCyclesDelay;
	rand int tlastNumOfCyclesDelay;
	rand int tuserNumOfCyclesDelay;
	rand int tvalidNumOfCyclesDelay;
	rand int tdataNumOfCyclesDelay;
	rand int resetNumOfCyclesDelay;
	function new(string name="AxiStreamSequenceItem");
		super.new(name);
	constraint NumOfCyclesDelayC {
		soft treadyNumOfCyclesDelay == 0;
		soft tlastNumOfCyclesDelay == 0;
		soft tuserNumOfCyclesDelay == 0;
		soft tvalidNumOfCyclesDelay == 0;
		soft tdataNumOfCyclesDelay == 0;
		soft resetNumOfCyclesDelay == 0;
	constraint ResetC {
		soft reset == 1;
	`uvm_object_param_utils_begin(AxiStreamSequenceItem#(DATA_WIDTH))
		`uvm_field_int(tready, UVM_DEFAULT)
		`uvm_field_int(tvalid, UVM_DEFAULT)
		`uvm_field_int(tuser, UVM_DEFAULT)
		`uvm_field_int(reset, UVM_DEFAULT)
		`uvm_field_int(tlast, UVM_DEFAULT)
		`uvm_field_int(tdata, UVM_DEFAULT)
	`uvm_object_utils_end
class AxiStreamMasterDriver#(parameter DATA_WIDTH) extends uvm_driver#(AxiStreamSequenceItem#(DATA_WIDTH));
	`uvm_component_param_utils(AxiStreamMasterDriver#(DATA_WIDTH))
	//Class Instances
	// Class Variables
	bit detectedSOF;
	bit disableEOL;
	bit disableValid;
	bit anotherEOL;
	bit[DATA_WIDTH-1:0] dataFIFO[$];
	int lineLength;
	int cameraId;
	uvm_event frameEnded;
	uvm_event anotherEOLEv;
	uvm_event EOLTooLateEv;
	uvm_event EOLTooSoonEv;
	uvm_event noEOLEv;
	//Driver Modport Interface
	virtual AxiStreamIf#(DATA_WIDTH) axiStreamMasterDriverVif;
	//Default Constructor
	extern function new(string name="AxiStreamMasterDriver", uvm_component parent);
	// UVM Phase functions/tasks
	extern function void build_phase(uvm_phase phase);
	extern task reset_phase(uvm_phase phase);
	extern task run_phase(uvm_phase phase);
	// Class related functions
	extern task resetDefault();
	extern function void detectSOF();
	extern task driveUser(AxiStreamSequenceItem#(DATA_WIDTH) req);
	extern task updatePixelCounter();
	extern task driveValid(AxiStreamSequenceItem#(DATA_WIDTH) req);
	extern task driveData(AxiStreamSequenceItem#(DATA_WIDTH) req);
	extern task driveLast();
endclass : AxiStreamMasterDriver
function AxiStreamMasterDriver::new(string name="AxiStreamMasterDriver", uvm_component parent);
	super.new(name, parent);
function void AxiStreamMasterDriver::build_phase(uvm_phase phase);
	super.build_phase(phase);
task AxiStreamMasterDriver::reset_phase(uvm_phase phase);
	phase.raise_objection(this);
	resetDefault();
	@(posedge axiStreamMasterDriverVif.reset);
	phase.drop_objection(this);
task AxiStreamMasterDriver::run_phase(uvm_phase phase);
	`uvm_info(get_type_name(), $psprintf("run_phase - %m Starting"), UVM_LOW)
	frameEnded = uvm_event_pool::get_global($sformatf("frameEnded_%0d", cameraId));
	anotherEOLEv = uvm_event_pool::get_global($sformatf("anotherEOLEv_%0d", cameraId));
	EOLTooLateEv = uvm_event_pool::get_global($sformatf("EOLTooLateEv_%0d", cameraId));
	EOLTooSoonEv = uvm_event_pool::get_global($sformatf("EOLTooSoonEv_%0d", cameraId));
	noEOLEv = uvm_event_pool::get_global($sformatf("noEOLEv_%0d", cameraId));
		begin: driverSignalsProc
			forever @(axiStreamMasterDriverVif.clockingBlock) begin
				if(axiStreamMasterDriverVif.reset) begin
					detectSOF();
					seq_item_port.try_next_item(req);
						driveData(req);
						driveValid(req);
						driveUser(req);
					join
					if (req != null) seq_item_port.item_done(req);
				else begin
					resetDefault();
		begin: driveTlastProc
				driveLast();
		begin: countPixelsProc
		begin: waitFrameEndProc
			forever begin
				frameEnded.wait_trigger();
				resetDefault();
		begin: anotherEOLProc
			forever begin
				anotherEOLEv.wait_trigger();
				anotherEOL = 1;
		begin: EOLTooLateProc
			forever begin
				EOLTooLateEv.wait_trigger();
				lineLength = IMG_WIDTH + 32;
		begin: EOLTooSoonProc
			forever begin
				EOLTooSoonEv.wait_trigger();
				lineLength = IMG_WIDTH - 32;
		begin: NoEOL
			forever begin
				noEOLEv.wait_trigger();
				disableEOL = 1;
	join
	`uvm_info(get_type_name(), $psprintf("run_phase - %m Finished"), UVM_LOW)
task AxiStreamMasterDriver::resetDefault();
	`uvm_info(get_type_name(), $psprintf("resetDefault Starting"), UVM_DEBUG)
	axiStreamMasterDriverVif.clockingBlock.tvalid <= 1'b0;
	axiStreamMasterDriverVif.clockingBlock.tuser <= 1'b0;
	axiStreamMasterDriverVif.clockingBlock.tlast <= 1'b0;
	axiStreamMasterDriverVif.clockingBlock.tdata <= 0;
	axiStreamMasterDriverVif.clockingBlock.pixelCounterOut <= 1;
	detectedSOF = 1'b0;
	dataFIFO.delete();
	`uvm_info(get_type_name(), $psprintf("resetDefault Finished"), UVM_DEBUG)
function void AxiStreamMasterDriver::detectSOF();
	if (axiStreamMasterDriverVif.tuser)
		detectedSOF = 1'b1;
endfunction // sofDetected
task AxiStreamMasterDriver::updatePixelCounter();
	axiStreamMasterDriverVif.clockingBlock.pixelCounterOut <= (axiStreamMasterDriverVif.clockingBlock.tready && axiStreamMasterDriverVif.tvalid && detectedSOF) ? ((axiStreamMasterDriverVif.pixelCounterOut % lineLength == 0) && axiStreamMasterDriverVif.pixelCounterOut != 0) ? 1 : axiStreamMasterDriverVif.pixelCounterOut + 1 : axiStreamMasterDriverVif.pixelCounterOut;
task AxiStreamMasterDriver::driveLast();
	if (disableEOL) axiStreamMasterDriverVif.clockingBlock.tlast <= 0;
	else if (axiStreamMasterDriverVif.tvalid && axiStreamMasterDriverVif.clockingBlock.tready && detectedSOF) begin
		if (((axiStreamMasterDriverVif.pixelCounterOut % (lineLength-1) == 0) && axiStreamMasterDriverVif.pixelCounterOut != 0) || anotherEOL) begin
			// clean event
			if (anotherEOL) anotherEOL = 0;
			axiStreamMasterDriverVif.clockingBlock.tlast <= 1;
endtask : driveLast
task AxiStreamMasterDriver::driveValid(AxiStreamSequenceItem#(DATA_WIDTH) req);
	if (axiStreamMasterDriverVif.tlast && axiStreamMasterDriverVif.clockingBlock.tready && axiStreamMasterDriverVif.tvalid) axiStreamMasterDriverVif.clockingBlock.tvalid <= 0;
	else begin
		if (req != null)
			axiStreamMasterDriverVif.clockingBlock.tvalid <= req.tvalid;
endtask : driveValid
task AxiStreamMasterDriver::driveData(AxiStreamSequenceItem#(DATA_WIDTH) req);
	if (req != null) begin
		if (req.tdata !== {DATA_WIDTH{1'bz}})
			dataFIFO.push_front(req.tdata);
		if (dataFIFO.size() != 0)
			axiStreamMasterDriverVif.clockingBlock.tdata <= dataFIFO.pop_back();
endtask : driveData
task AxiStreamMasterDriver::driveUser(AxiStreamSequenceItem#(DATA_WIDTH) req);
	if (!detectedSOF) axiStreamMasterDriverVif.clockingBlock.tuser <= 1'b1;
	else axiStreamMasterDriverVif.clockingBlock.tuser <= (axiStreamMasterDriverVif.tvalid && axiStreamMasterDriverVif.clockingBlock.tready) ? 1'b0 : axiStreamMasterDriverVif.clockingBlock.tuser;
class AxiStreamSlaveDriver#(parameter DATA_WIDTH) extends uvm_driver#(AxiStreamSequenceItem#(DATA_WIDTH));
	`uvm_component_param_utils(AxiStreamSlaveDriver#(DATA_WIDTH))
	//Class Instances
	virtual interface AxiStreamIf#(DATA_WIDTH) axiStreamSlaveDriverVif;
	bit detectedSOF;
	int cameraId;
	extern function new(string name="AxiStreamSlaveDriver", uvm_component parent);
	extern task driveSignals(AxiStreamSequenceItem#(DATA_WIDTH) req);
endclass : AxiStreamSlaveDriver
function AxiStreamSlaveDriver::new(string name="AxiStreamSlaveDriver", uvm_component parent);
function void AxiStreamSlaveDriver::build_phase(uvm_phase phase);
task AxiStreamSlaveDriver::reset_phase(uvm_phase phase);
	resetDefault();
	@(posedge axiStreamSlaveDriverVif.reset);
task AxiStreamSlaveDriver::run_phase(uvm_phase phase);
			forever @(axiStreamSlaveDriverVif.clockingBlockSlave) begin
				if(!axiStreamSlaveDriverVif.reset)
					resetDefault();
				else begin
					if (axiStreamSlaveDriverVif.tuser)
						detectedSOF = 1;
						driveSignals(req);
	join
task AxiStreamSlaveDriver::updatePixelCounter();
	axiStreamSlaveDriverVif.clockingBlockSlave.pixelCounterIn <= (axiStreamSlaveDriverVif.tready && axiStreamSlaveDriverVif.clockingBlockSlave.tvalid && detectedSOF) ? (((axiStreamSlaveDriverVif.pixelCounterIn % ParametersPkg::IMG_WIDTH == 0) && axiStreamSlaveDriverVif.pixelCounterIn != 0) ? 1 : axiStreamSlaveDriverVif.pixelCounterIn + 1) : axiStreamSlaveDriverVif.pixelCounterIn;
task AxiStreamSlaveDriver::resetDefault();
	axiStreamSlaveDriverVif.clockingBlockSlave.tready <= 1'b0;
	axiStreamSlaveDriverVif.clockingBlockSlave.pixelCounterIn <= 1;
task AxiStreamSlaveDriver::driveSignals(AxiStreamSequenceItem#(DATA_WIDTH) req);
	axiStreamSlaveDriverVif.clockingBlockSlave.tready<=req.tready;
class AxiStreamMonitor#(parameter DATA_WIDTH_IN, parameter DATA_WIDTH_OUT) extends uvm_monitor;
	`uvm_component_param_utils(AxiStreamMonitor#(DATA_WIDTH_IN, DATA_WIDTH_OUT))
	virtual interface AxiStreamIf#(DATA_WIDTH_OUT) axiStreamMonitorVif;
	AxiStreamSequenceItem#(DATA_WIDTH_OUT) monitorTrans;
	uvm_analysis_port #(AxiStreamSequenceItem#(DATA_WIDTH_OUT)) AxiStreamAnalysisPort;
	extern function new(string name="AxiStreamMonitor", uvm_component parent);
	extern virtual function void build_phase(uvm_phase phase);
	extern task collectMasterSignals();
endclass : AxiStreamMonitor
function AxiStreamMonitor::new(string name="AxiStreamMonitor", uvm_component parent);
	super.new(name,parent);
function void AxiStreamMonitor::build_phase(uvm_phase phase);
	AxiStreamAnalysisPort = new("AxiStreamAnalysisPort", this);
	monitorTrans = AxiStreamSequenceItem#(DATA_WIDTH_OUT)::type_id::create("monitorTrans", this);
task AxiStreamMonitor::reset_phase(uvm_phase phase);
	@(posedge axiStreamMonitorVif.reset);
task AxiStreamMonitor::run_phase(uvm_phase phase);
	forever @(negedge axiStreamMonitorVif.clk) begin
task AxiStreamMonitor::collectMasterSignals();
	if (axiStreamMonitorVif.reset) begin
		monitorTrans.tdata=axiStreamMonitorVif.tdata;
		monitorTrans.tvalid=axiStreamMonitorVif.tvalid;
		monitorTrans.tready=axiStreamMonitorVif.tready;
		monitorTrans.tuser=axiStreamMonitorVif.tuser;
		monitorTrans.tlast=axiStreamMonitorVif.tlast;
		AxiStreamAnalysisPort.write(monitorTrans);
This is too much code to go through on this forum, yet not enough to be able to recreate your issue. At least from my point of view given the time I have to look at it.
I appreciate it.
