I want to write a simple assertion as:
property trigger_check;
$rose(a) |-> ##{depending on CLK_CYC } $rose(b) ##1 $fell(b);
endproperty : trigger_check
Now, based on the value of CLK_CYC, the number of delay cycles should be:
- 0 : 20 clock cycles
- 1 : 50 clock cycles
- 2 : 180 clock cycles
- 3 : 290 clock cycles
Note: CLK_CYC is updated before posedge in a arrives
How can i implement this using the above assertion?
