In reply to MICRO_91:
In reply to haykp:
Its just a code I was trying in reference to a question I saw on the forum about Connecting multiple sequencers connected to a driver .
In the UVM you have alot of freedom, because there are no compliance rules. The question is why do you need this. The most important rule in constructing a UVM testbench is: make it as easy as possible!
In your driver you can serve only 1 seq_item at the same time. Why do you need 2 seq_item?
Please explain.
