Hello all,
I am a beginner in UVM and I am trying to implement the verification for a mod 12 counter. But I am facing an error called null object reference in my environement connect phase. I have check all the lowler level components, if I have missed creating an object for them. I could not find any object not created. I have also checked if proper arguments to the function new construct are mentioned properly, againg could not find any fault. I have also check the configuration data base paramenters if they are set or not, still no luck.
Access the entire code by my git hub link: GitHub - MVS-Abhiram/Mod--12-Counter-Verification: This project deals with the verification of MOD 12 Counter
The code which I have developed is given below
---------------------------- MOD 12 COUNTER PROJECT UVM VERIFICATION-----------------------------
AUTHOR: MVS ABHIRAM
import uvm_pkg::*;
`include "uvm_macros.svh"
---------------------------------------RTL CODE-------------------------------------------------
module Mod_12_loadable_up_down_counter(clk,rst,load,mode,data_in,data_out);
input clk,rst,load,mode;
input [3:0]data_in;
output reg [3:0]data_out;
always @(posedge clk) begin
if (rst) begin
data_out <= 4'b0000; // Reset to 0.
else if (load) begin
data_out <= data_in; // Load new value.
else if (mode) begin
// Increment (Up) mode, with mod-12 check
if (data_out == 4'b1011) begin // If data_out is 11, next value should be 0.
end else begin
data_out <= data_out + 1;
else begin
// Decrement (Down) mode, with mod-12 check
if (data_out == 4'b0000) begin // If data_out is 0, next value should be 11.
data_out <= 4'b1011;
end else begin
data_out <= data_out - 1;
---------------------------------------INTERFACE BLOCK------------------------------------------
interface counter_if(input bit clk);
// Ports decleration
bit mode;
bit load;
bit rst;
bit [3:0] data_in;
bit [3:0] data_out;
// Write Driver Clocking block
clocking wr_drv_cb @(posedge clk);
default input #1 output #0;
output mode;
output load;
output rst;
output data_in;
//output data_out;
endclocking : wr_drv_cb;
// Write Monitor clocking block
clocking wr_mon_cb @(posedge clk);
input mode;
input load;
input rst;
input data_in;
//output data_out;
endclocking : wr_mon_cb
// Read Monitor Clocking Block
clocking rd_mon_cb @(posedge clk);
input data_out;
endclocking: rd_mon_cb
//Write Driver Modport decleration
modport WR_DRV_MP (clocking wr_drv_cb);
//Write Monitor Modport decleration
modport WR_MON_MP (clocking wr_mon_cb);
//Read Monnitor Modport delceration
modport RD_MON_MP (clocking rd_mon_cb);
modport DUV_MP (input clk,rst,load,mode,data_in, output data_out);
endinterface : counter_if
module counter_chip (counter_if.DUV_MP c_if);
Mod_12_loadable_up_down_counter UUT (.clk(c_if.clk),
.rst(c_if.rst),
.load(c_if.load),
.mode(c_if.mode),
.data_out(c_if.data_out),
.data_in(c_if.data_out));
--------------------------------------READ AGENT CONFIGURATION CLASS CODE---------------------
class rd_agent_config extends uvm_object;
`uvm_object_utils(rd_agent_config)
function new(string name = "rd_agent_config");
super.new(name);
uvm_active_passive_enum is_active = UVM_PASSIVE;
virtual counter_if vif;
endclass: rd_agent_config
--------------------------------------WRITE AGENT CONFIGURATION CLASS CODE---------------------
class wr_agent_config extends uvm_object;
`uvm_object_utils(wr_agent_config)
function new(string name ="wr_agent_config");
super.new(name);
uvm_active_passive_enum is_active = UVM_ACTIVE;
endclass: wr_agent_config
---------------------------------------ENVIRONMENT CONFIGURATION CLASS CODE---------------------
class env_config extends uvm_object;
`uvm_object_utils(env_config)
function new(string name = "env_config");
super.new(name);
int has_read_agent = 1;
int has_write_agent = 1;
int has_score_board = 1;
int has_virtual_sequencer = 1;
rd_agent_config rd_agent_configh;
wr_agent_config wr_agent_configh;
endclass : env_config
--------------------------------------WRITE TRANSCTIONS CLASS CODE------------------------------
class write_xtn extends uvm_sequence_item;
`uvm_object_utils(write_xtn)
function new(string name ="write_xtn");
super.new(name);
rand bit rst;
rand bit load;
rand bit mode;
rand bit [3:0] data_in;
constraint valid_rst {rst dist {0:= 80, 1:= 20};}
constraint valid_load {load dist{0:= 80, 1:=20};}
constraint valid_mode {mode dist{0:= 60, 1:=40};}
constraint valid_data_in {data_in inside {[0:11]};}
endclass : write_xtn
---------------------------------------READ TRANSCATIONS CODE-----------------------------------
class read_xtn extends uvm_sequence_item;
`uvm_object_utils(read_xtn)
function new(string name ="read_xtn");
super.new(name);
bit [3:0] data_out;
endclass : read_xtn
--------------------------------------SEQUENCE CLASS CODE---------------------------------------
class my_seq extends uvm_sequence #(write_xtn);
`uvm_object_utils(my_seq)
function new(string name = "my_seq");
super.new(name);
task body();
repeat(10) begin
req = write_xtn::type_id::create("req");
start_item(req);
assert(req.randomize());
finish_item(req);
endclass: my_seq
--------------------------------------TOP MODULE CODE-------------------------------------------
module top();
bit clock = 0;
always #5 clock = ~clock;
counter_if in0(clock);
counter_chip ch(in0);
uvm_config_db#(virtual counter_if)::set(null,"*","in0",in0);
run_test("my_test");
endmodule: top
--------------------------------------WRITE DRIVER CLASS CODE-----------------------------------
class wr_driver extends uvm_driver #(write_xtn);
`uvm_component_utils(wr_driver);
wr_agent_config wr_cfg;
virtual counter_if.WR_DRV_MP vif;
function new(string name = "wr_driver", uvm_component parent);
super.new(name, parent);
super.build_phase(phase);
uvm_config_db#(wr_agent_config)::get(this,"","wr_agent_config",wr_cfg);
super.connect_phase(phase);
vif = wr_cfg.vif;
task run_phase (uvm_phase phase);
super.run_phase(phase);
forever begin
send_to_dut(req);
seq_item_port.item_done();
task send_to_dut(write_xtn xtn);
`uvm_info("WR_DRIVER",$sformatf("printing from driver \n %s", xtn.sprint()),UVM_LOW)
// Driving the data to DUV on the posedge of the clock
@(vif.wr_drv_cb)
vif.wr_drv_cb.rst <= xtn.rst;
vif.wr_drv_cb.load <= xtn.load;
vif.wr_drv_cb.mode <= xtn.mode;
vif.wr_drv_cb.data_in <= xtn.data_in;
function void end_of_elaboration_phase(uvm_phase phase);
uvm_top.print_topology();
endclass: wr_driver
--------------------------------------WRITE MONITOR CLASS CODE----------------------------------
class wr_mon extends uvm_monitor;
`uvm_component_utils(wr_mon)
virtual counter_if.WR_MON_MP vif;
uvm_analysis_port #(write_xtn) monitor_port;
function new(string name ="wr_mon", uvm_component parent);
super.new(name,parent);
monitor_port = new("monitor_port",this);
vif = wr_cfg.vif;
forever
monitor();
task monitor();
write_xtn xtn;
xtn = write_xtn::type_id::create("xtn");
//Sampling the singnal for the dut interface
xtn.rst <= vif.wr_mon_cb.rst;
xtn.load <= vif.wr_mon_cb.load;
xtn.mode <= vif.wr_mon_cb.mode;
xtn.data_in <= vif.wr_mon_cb.data_in;
`uvm_info("WR_MONITOR",$sformatf("printing from write monitor \n %s", xtn.sprint()),UVM_LOW)
// Sending data to score Board
monitor_port.write(xtn);
endclass: wr_mon
--------------------------------------WRITE SEQUENCER CLASS CODE--------------------------------
class wr_seqr extends uvm_sequencer #(write_xtn);
`uvm_component_utils(wr_seqr)
function new(string name ="wr_seqr",uvm_component parent);
endclass : wr_seqr
--------------------------------------READ MONITOR CLASS CODE----------------------------------
class rd_mon extends uvm_monitor;
`uvm_component_utils(rd_mon)
virtual counter_if.RD_MON_MP vif;
rd_agent_config rd_cfg;
uvm_analysis_port #(read_xtn) monitor_port1;
function new(string name ="rd_mon", uvm_component parent);
monitor_port1 = new("monitor_port1",this);
uvm_config_db#(rd_agent_config)::get(this,"","rd_agent_config",rd_cfg);
vif = rd_cfg.vif;
forever
monitor();
task monitor();
read_xtn xtn;
xtn = read_xtn::type_id::create("xtn");
xtn.data_out <= vif.rd_mon_cb.data_out;
//`uvm_info("RD_MONITOR",$sformatf("printing from read monitor \n %s", xtn.sprint()),UVM_LOW)
monitor_port1.write(xtn);
endclass: rd_mon
--------------------------------------READ AGENT CLASS CODE-------------------------------------
class rd_agent extends uvm_agent;
`uvm_component_utils(rd_agent)
rd_mon rd_monh;
function new(string name ="rd_agent",uvm_component parent);
phase.raise_objection(this);
if(rd_cfg.is_active == UVM_PASSIVE)
rd_monh = rd_mon::type_id::create("rd_monh",this);
phase.drop_objection(this);
endclass: rd_agent
--------------------------------------WRITE AGENT CLASS CODE-------------------------------------
class wr_agent extends uvm_agent;
`uvm_component_utils(wr_agent)
wr_driver wr_drvh;
wr_mon wr_monh;
wr_seqr wr_seqrh;
function new(string name ="wr_agent",uvm_component parent);
function void build_phase (uvm_phase phase);
wr_monh = wr_mon::type_id::create("wr_monh",this);
if(wr_cfg.is_active == UVM_ACTIVE) begin
wr_drvh = wr_driver::type_id::create("wr_cfg",this);
wr_seqrh = wr_seqr::type_id::create("wr_seqrh",this);
function void connect_phasse(uvm_phase phase);
wr_drvh.seq_item_port.connect(wr_seqrh.seq_item_export);
endclass: wr_agent
--------------------------------------AGENT TOP CLASS CODE--------------------------------------
class agent_top extends uvm_component;
`uvm_component_utils(agent_top)
env_config m_cfg;
rd_agent rd_agenth;
wr_agent wr_agenth;
function new(string name = "agent_top",uvm_component parent);
uvm_config_db#(env_config)::get(this,"","env_config",m_cfg);
if(m_cfg.has_read_agent) begin
rd_agenth = rd_agent::type_id::create("rd_agenth",this); end
if(m_cfg.has_write_agent) begin
wr_agenth = wr_agent::type_id::create("wr_agenth",this); end
endclass: agent_top
--------------------------------------VIRTUAL SEQUENCER CLASS CODE------------------------------
class v_sequencer extends uvm_sequencer;
`uvm_component_utils(v_sequencer)
wr_seqr wr_seqrh;
function new(string name ="v_sequencer",uvm_component parent);
endclass : v_sequencer
--------------------------------------VIRTUAL SEQUENCE CLASS CODE-------------------------------
class virtual_seq_base extends uvm_sequence #(uvm_sequence_item);
`uvm_object_utils(virtual_seq_base)
wr_seqr wr_seqrh;
v_sequencer vseqrh;
function new(string name ="virtual_seq");
super.new(name);
task body();
if(!$cast(vseqrh,m_sequencer))
`uvm_info("VIRTUAL_SEQUENCE","Casting not Successful",UVM_HIGH)
wr_seqrh = vseqrh.wr_seqrh;
class rand_seq extends virtual_seq_base;
`uvm_object_utils(rand_seq)
my_seq my_seqrh;
function new(string name = "rand_seq");
super.new(name);
task body();
super.body();
my_seqrh.start(wr_seqrh);
endclass : rand_seq
--------------------------------------SCOREBOARD CLASS CODE-------------------------------------
class sb extends uvm_scoreboard;
`uvm_component_utils(sb)
uvm_tlm_analysis_fifo #(write_xtn) fifo_wr;
uvm_tlm_analysis_fifo #(read_xtn) fifo_rd;
write_xtn wr_data;
read_xtn rd_data;
static bit [3:0] data_out_sb;
function new(string name ="sb", uvm_component parent);
fifo_wr = new("fifo_wr",this);
fifo_rd = new("fifo_rd",this);
forever begin
fifo_wr.get(wr_data);
counter(wr_data);
forever begin
fifo_rd.get(rd_data);
check_data(rd_data);
join
function void counter (write_xtn wr_data);
if (wr_data.rst) begin
data_out_sb <= 4'b0000; // Reset to 0.
else if (wr_data.load) begin
data_out_sb <= wr_data.data_in; // Load new value.
else if (wr_data.mode) begin
if (data_out_sb == 4'b1011) begin // If data_out is 11, next value should be 0.
end else begin
data_out_sb <= data_out_sb + 1;
else begin
if (data_out_sb == 4'b0000) begin // If data_out is 0, next value should be 11.
data_out_sb <= 4'b1011;
end else begin
data_out_sb <= data_out_sb - 1;
function void check_data(read_xtn rd_data);
if(rd_data.data_out == data_out_sb) begin
`uvm_info("SB","Data Matched Successful",UVM_HIGH)
$display("Read Monitor data out %0d",rd_data.data_out);
$display("Reference Model data out %0d",data_out_sb);
else begin
`uvm_info("SB","Data Not Matched UN-Successful",UVM_HIGH)
endclass: sb
--------------------------------------ENVIRONMENT CLASS CODE------------------------------------
class my_env extends uvm_env;
`uvm_component_utils(my_env)
v_sequencer v_seqrh;
env_config m_cfg;
agent_top agent_toph;
rd_agent rd_agenth;
wr_agent wr_agenth;
sb sbh;
function new(string name ="my_env", uvm_component parent);
agent_toph = agent_top::type_id::create("agent_toph",this);
//rd_agenth = rd_agent::type_id::create("rd_agenth",this);
uvm_config_db#(rd_agent_config)::set(this,"*","rd_agent_config",m_cfg.rd_agent_configh);
//wr_agenth = wr_agent::type_id::create("wr_agenth",this);
uvm_config_db#(wr_agent_config)::set(this,"*","wr_agent_config",m_cfg.wr_agent_configh);
if(m_cfg.has_score_board)
sbh = sb::type_id::create("sbh",this);
if(m_cfg.has_virtual_sequencer)
v_seqrh = v_sequencer::type_id::create("v_seqrh",this);
// COnnect monitor to sb (Monitor is initiator)
wr_agenth.wr_monh.monitor_port.connect(sbh.fifo_wr.analysis_export);
rd_agenth.rd_monh.monitor_port1.connect(sbh.fifo_rd.analysis_export);
// COnnect virtual sequencer handels to physical sequencers
v_seqrh.wr_seqrh =agent_toph.wr_agenth.wr_seqrh;
endclass: my_env
--------------------------------------TEST CLASS CODE-------------------------------------------
`uvm_component_utils(my_test)
rand_seq rand_seqh;
my_env envh;
env_config m_cfg;
function new(string name = "my_test",uvm_component parent);
m_cfg = env_config::type_id::create("m_cfg");
uvm_config_db#(virtual counter_if)::get(this,"","in0",m_cfg.vif);
rd_cfg = rd_agent_config::type_id::create("rd_cfg");
if(!uvm_config_db#(virtual counter_if)::get(this,"","in0",rd_cfg.vif))
`uvm_fatal("TEST","Getting virtual interface failed in test class for read config");
m_cfg.rd_agent_configh =rd_cfg;
if (m_cfg.has_write_agent) begin
wr_cfg = wr_agent_config::type_id::create("wr_cfg");
if(!uvm_config_db#(virtual counter_if)::get(this,"","in0",wr_cfg.vif))
`uvm_fatal("TEST","Getting virtual interface faild in test class for write config")
m_cfg.wr_agent_configh = wr_cfg;
uvm_config_db#(env_config)::set(this,"*","env_config",m_cfg);
envh = my_env::type_id::create("envh",this);
rand_seqh = rand_seq::type_id::create("rand_seqh");
rand_seqh.start(envh.v_seqrh);
endclass: my_test
The error I am getting
" UVM_INFO @ 0: reporter [RNTST] Running test my_test...
UVM_WARNING @ 0: build_objection [OBJTN_CLEAR] Object 'uvm_top' cleared objection counts for build_objection
Error-[NOA] Null object access
counter.sv, 740
The object at dereference depth 1 is being used before it was
constructed/allocated.
Please make sure that the object is allocated before using it.
#0 in \my_env::connect_phase at counter.sv:740
#1 in \uvm_connect_phase::exec_func at
/home/cad/eda/SYNOPSYS/VCS/vcs/T-2022.06-SP1/etc/uvm/base/uvm_common_phases.svh:96
#2 in \uvm_bottomup_phase::execute at
/home/cad/eda/SYNOPSYS/VCS/vcs/T-2022.06-SP1/etc/uvm/base/uvm_bottomup_phase.svh:108
#3 in \uvm_bottomup_phase::traverse at
/home/cad/eda/SYNOPSYS/VCS/vcs/T-2022.06-SP1/etc/uvm/base/uvm_bottomup_phase.svh:81
#4 in \uvm_bottomup_phase::traverse at
/home/cad/eda/SYNOPSYS/VCS/vcs/T-2022.06-SP1/etc/uvm/base/uvm_bottomup_phase.svh:61
#5 in \uvm_bottomup_phase::traverse at
#6 in \uvm_phase::execute_phase at
/home/cad/eda/SYNOPSYS/VCS/vcs/T-2022.06-SP1/etc/uvm/base/uvm_phase.svh:1162
#7 in \uvm_phase::m_run_phases at
/home/cad/eda/SYNOPSYS/VCS/vcs/T-2022.06-SP1/etc/uvm/base/uvm_phase.svh:1858
#8 in \uvm_root::run_test at
/home/cad/eda/SYNOPSYS/VCS/vcs/T-2022.06-SP1/etc/uvm/base/uvm_root.svh:424
Kindly help me unterstand where I have made a mistake in my design.
Thanks in Advance
