Hi Dave,
I have a
base_test extends uvm_test
and
test1 extends base_test
- If I don’t declare/define build_phase in test1, the base_test’s build_phase is called/executed automatically
- If I declare/define buil_phase in test1, and call super.build_phase() here, the base_test’s build_phase is called/executed again after the above automatic call/execution?
- What is the difference between the two above?
- How can I completely override base_class’s build_phase, as it is automatically called in uvm? This is required if I need to completely override a common register config from base_test to test1.
-mpattaje
