There is 1-bit input called valid along with a clk. There is also 1-bit grant. Now implement a assertion which will monitor this valid and grant in such a way that after every rise of valid , task must see and make sure grant is received within 15 clocks, else it must through error. Remember that
Multiple valids will receive multiple grants at different time intervals , but in same order the valids were recieved
You will need some extra logic that counts the number of valid and grant edges, but this should get you started
property vg;
int count;
@(posedge clk)
($rose(valid), count = valid_count) |-> ##[1:15] $rose(grant) && count == grant_count;
Thanks @dave_59 for the solution. This will help.
