In reply to Dhruvesh.b:
Thanks for the details.
You’ll never replace the $display in the future and the uvm_info is not more complicated.
From your explanations I get now a complete different impression. You do 3 write commands tgo complete 1 bus command. Right?
Whay do you not use the addr field in the rw. To specify your address. And you could put together all 2 values in 1 write command.
