Multi Layered structure array is not getting created inside constraint policy approach
Hello !
  1. I have bunch of structures and some of them are multi layered.
  2. When I write constraints to create the arrays, it works fine when constrains are added directly in the class as shown below.
Code:
module maui;
    typedef struct {
      rand real aa[];
      rand real bb[];
    } ab_struct_s;
    typedef struct {
      rand integer step_num;
      rand ab_struct_s oa_0;
    } gs_struct_s;
    typedef struct {
      rand integer num_fac;
      rand real acl_abc;
      rand gs_struct_s gs_struct[];
      rand integer oha[];
    } fv_struct_s;
    class maui;
        rand fv_struct_s fv_struct;
        constraint fov_struct_c {
           fv_struct.acl_abc == 1.456;
           fv_struct.gs_struct.size() == 2;
           fv_struct.oha.size() == 5;
           fv_struct.gs_struct[0].oa_0.aa.size() == 2;
           fv_struct.gs_struct[0].oa_0.bb.size() == 2;
           fv_struct.gs_struct[1].oa_0.aa.size() == 4;
           fv_struct.gs_struct[1].oa_0.bb.size() == 4;
    endclass: maui
        maui mm = new();
        assert(mm.randomize());
        $display("mm: %0p\n", mm);
endmodule: maui
Output:
mm: '{fv_struct:'{num_fac:436169175, acl_abc:1.456, gs_struct:'{'{step_num:1261410630, oa_0:'{aa:'{1543857315105.327, 8.712996039271156e-07}, bb:'{-2.400445456556682e-11, 0.008615784022056735}}}, '{step_num:2049814541, oa_0:'{aa:'{-1.197309124675167e-12, 95.84324722893554, -0.000162805931616192, -1.270639223379571e-08}, bb:'{-6.877835401836651e-07, 0.008630354298874768, 3.934404050926106e-10, -0.2016849396089287}}}}, oha:'{-2087058360, -747428130, 1443735644, 62258165, -1241979847}}}
  1. When I try the same code using constraint policy list, the simulation doesn’t error out but it doesn’t create the necessary arrays.
Code:
`include "uvm_macros.svh"
 import uvm_pkg::*;
module maui;
    typedef struct {
      rand real aa[];
      rand real bb[];
    } ab_struct_s;
    typedef struct {
    } gs_struct_s;
    typedef struct {
      rand real acl_abc;
      rand integer oha[];
    } fv_struct_s;
    class policy_base#(type ITEM=uvm_object);
        ITEM item;
        virtual function void set_item(ITEM item);
            this.item = item;
        function pre_randomize();
            get_plusargs();
        endfunction: pre_randomize
        virtual function get_plusargs();
        endfunction: get_plusargs
    endclass: policy_base
    class policy_list#(type ITEM=uvm_object) extends policy_base #(ITEM);
        rand policy_base#(ITEM) policy[$];
        function void add(policy_base#(ITEM) pcy);
            policy.push_back(pcy);
            foreach(policy[i]) begin
                policy[i].set_item(item);
    endclass: policy_list
    // Top Level Constraints
    class top_gen_base;
        rand policy_base #(top_gen_base) top_policy[$];
        function new();
        endfunction: new
            foreach (top_policy[i]) begin
                top_policy[i].set_item(this);
    endclass: top_gen_base
    class top_fv_struct extends policy_base #(top_gen_base);
        constraint item_c {
           soft item.fv_struct.acl_abc == 1.456;
           soft item.fv_struct.gs_struct.size() == 2;
           soft item.fv_struct.oha.size() == 5;
           // soft item.fv_struct.gs_struct[0].oa_0.aa.size() == 2;
           // soft item.fv_struct.gs_struct[0].oa_0.bb.size() == 2;
           // soft item.fv_struct.gs_struct[1].oa_0.aa.size() == 4;
           // soft item.fv_struct.gs_struct[1].oa_0.bb.size() == 4;
    endclass: top_fv_struct
    class top_gen extends top_gen_base;
        policy_list#(top_gen_base) top_pcy;
        function new();
            top_fv_struct       tfs;
            top_pcy = new;
            tfs = new();
            top_pcy.add(tfs);
            top_policy.push_back(top_pcy);
        endfunction: new
    endclass: top_gen
        top_gen  tg = new();
        assert(tg.randomize());
        $display("tg = %0p\n", tg);
endmodule: maui
Output:
tg = '{super:'{top_policy:'{maui.policy_base#(top_gen_base)@1810_1}, fv_struct:'{num_fac:70243015, nacl_abc:1.456, gs_struct:'{}, oha:'{2139805943, 894566753, 42405809, 2015313403, -86690185}}},
I am confused what is affecting in the constraint policy which is not allowing to create the struct array.
Any comments would be helpful. Thanks.
Note: Please ignore the garbage value of the real numbers.
You have have a number of differences between the two codes
  1. missing rand qualifiers
  2. commented out constraints on array sizes
  3. missing void return types on functions
  4. constraints on real numbers is a SystemVerilog1800-2023 feature that many tools do not support by default.
  5. UVM code was unnecessary and cluttered up the example.
This code worked for me
module maui;
   typedef struct {
      rand real aa[];
      rand real bb[];
   } ab_struct_s;
   typedef struct {
   } gs_struct_s;
   typedef struct {
      rand real acl_abc;
      rand integer oha[];
   } fv_struct_s;
class policy_base#(type ITEM);
   rand ITEM item;
      this.item = item;
class policy_list#(type ITEM) extends policy_base #(ITEM);
class top_gen_base;
   constraint item_c {
   rand policy_list#(top_gen_base) top_pcy;
   function new();
      top_fv_struct       tfs;
      top_pcy = new;
      tfs = new();
      top_pcy.add(tfs);
   endfunction: new
endclass: top_gen
      static top_gen  tg = new();
      $display("tg = %p\n", tg);
endmodule: maui
Hello @dave_59 Thanks for your timely response.
  1. Kinda-off confused how the code works at your end ? I.e. without setting the link to the object using set_item how is the following line item.fv_struct inside the class top_fv_struct works ?
  2. Also, when I tried running your code in the EDA playground with simulator type Mentor Questa 2021.3 I faced the below error. May be this is some old version of the tool.
# ** Error: (vsim-7073) testbench.sv(50): Attempt to dereference null class reference (top_policy[0].policy[0].item.fv_struct) in constraint.
#    Time: 0 ns  Iteration: 0  Process: /maui/#INITIAL#76(#ublk#473273#76) File: testbench.sv Line: 78
# ** Error: Assertion error.
#    Time: 0 ns  Scope: maui File: testbench.sv Line: 78
# tg = '{top_policy:'{@policy_list__1@1}, fv_struct:'{num_fac:x, acl_abc:0, gs_struct:'{}, oha:'{}}, top_pcy:@policy_list__1@1}
# exit
