I currently have a component (named ‘sequencer’), which I want to be replaced with another component (name ‘proj_sequencer’) whenever an instance of type ‘sequencer’ is created.
I have tried implementing the code shown below and I am stuck with compile error. [MFNF] Member not found i.e. class member ‘a’ for the extended class.
However when I comment the line
env.sqr.a = 5;
I can see the environment hierarchy printed as expected with the overidden class type.
Would appreciate if anyone could point out where I am going wrong, and what is wrong with my approach.
Everything in reference to below sample code
// Base Sequencer
class sequencer extends uvm_component;
`uvm_component_utils(sequencer)
function new(string name = "sequencer", uvm_component parent);
super.new(name, parent);
// Project Sequencer
class proj_sequencer extends sequencer;
int a; // Added class member
`uvm_component_utils_begin(proj_sequencer)
`uvm_field_int(a, UVM_ALL_ON)
`uvm_component_utils_end
function new(string name = "proj_sequencer", uvm_component parent);
// Environment
class top_env extends uvm_env;
`uvm_component_utils(top_env)
sequencer sqr;
function new(string name = "top_env", uvm_component parent);
super.build_phase(phase);
sqr = sequencer::type_id::create("sqr", this);
// Top Test
class top_test extends uvm_test;
`uvm_component_utils(top_test)
top_env env;
function new(string name = "top_test", uvm_component parent);
set_type_override_by_type(sequencer::get_type(), proj_sequencer::get_type());
env = top_env::type_id::create("env", this);
virtual function void connect_phase(uvm_phase phase);
super.connect_phase(phase);
virtual function void end_of_elaboration_phase(uvm_phase phase);
super.end_of_elaboration_phase(phase);
env.sqr.a = 5;
env.print();
