Issue with modulation in ASIC porject WiMax
module modulation (
    input  logic clk,
    input  logic reset,
    input  logic enable,
    input  logic input1,
    input  logic ready,                  // Handshake signal: Ready from downstream
    output logic signed [15:0] output1,
    output logic signed [15:0] output2,
    output logic valid
    // Internal signals
    logic [2:0] counter;
    logic [1:0] b;
    logic signed [15:0] seven = 16'h5A82;
    logic signed [15:0] seven_negative = 16'hA57E;
    typedef enum logic [1:0] {IDLE, LOAD, PROCESS, DONE} state_t;
    state_t current_state, next_state;
    // Sequential logic: State and counter
    always_ff @(posedge clk or posedge reset) begin
        if (reset) begin
            current_state <= IDLE;
            counter <= 3'b000;
            b <= 2'b00;
        end else begin
            current_state <= next_state;
            if (current_state == LOAD && enable) begin
                counter <= (counter == 3'b010) ? 3'b000 : counter + 1;
                b <= {b[0], input1};
    // Next state logic (FSM)
    always_comb begin
        next_state = current_state;  // Default to current state
        case (current_state)
            IDLE:
                if (enable) next_state = LOAD;
            LOAD:
                if (counter == 3'b010) next_state = PROCESS;
            PROCESS:
                if (ready) next_state = DONE;
            DONE:
                next_state = IDLE;  // Return to idle after completion
            default:
                next_state = IDLE;
        endcase
    // Output logic and handshake
    always_comb begin
        valid = 1'b0;
        output1 = '0;
        output2 = '0;
        if (current_state == PROCESS) begin
            valid = 1'b1;  // Signal that output is valid
            case (b)
                2'b00: begin
                    output1 = seven;
                    output2 = seven;
                2'b01: begin
                    output1 = seven;
                    output2 = seven_negative;
                2'b10: begin
                    output1 = seven_negative;
                    output2 = seven;
                2'b11: begin
                default: begin
                    output1 = '0;
                    output2 = '0;
            endcase
module modulation_test;
    // Declare signals
    logic clk;
    logic reset;
    logic enable;
    logic ready;
    logic valid;
    logic input1;
    logic signed [15:0] output1;
    logic signed [15:0] output2;
    logic [11:0] hexin;
    // Initialize the hexin signal
    initial hexin = 12'h4B0;
    // Instantiate the DUT
    modulation dut (
        .clk(clk),
        .reset(reset),
        .enable(enable),
        .input1(input1),
        .output1(output1),
        .output2(output2),
        .ready(ready),
        .valid(valid)
    // Clock generation
    initial clk = 1'b1;
    always #50 clk = ~clk;  // 50 MHz clock
    // Stimulus process
        reset = 1'b1;
        enable = 1'b0;
        ready = 1'b0;
        #100;
        reset = 1'b0;
        enable = 1'b1;
        for (int i = 0; i < 12; i++) begin
            input1 = hexin[i];
            ready = 1'b1;  // Simulate ready signal
            #100;
        // End simulation
        #100;
        $finish;
i have no clue how i can fix, i am new at this program.
We have no clue how to fix something we don’t know what is wrong.
