Is there a way to use SVA property's local variable value to be used outside property
In reply to Monarch Dave:
SVA does not allow the access of local variables from the action block.
Some simulators do report the value of the variables upon a failure. However, if you absolutely want to have access you can do what I have in the example below. In this example,
the property is
(a, v=b, t=$realtime) |=> (b==v); // where b and v are int.
module top;
	bit clk, a;
	int b, temp;
	string tID="My project";
	realtime tr;
	initial forever #10 clk=!clk;
	function void report_fail(int v, b, realtime t);
	   if (b!=v)
  `uvm_info(tID,$sformatf("Fail for @attempt time=%t v=%d, b=%d", t, v, b), UVM_LOW);
	property p_test;
		int v;
		realtime t;
		(a, v=b, t=$realtime) |=> (1, report_fail(v, b, t)) ##0 (b==v);
	ap_test: assert property(p_test);
     repeat(200) begin
       @(posedge clk);
       #2 if (!randomize(a, b)  with
           { a dist {1'b1:=2, 1'b0:=1};
             b inside {[2:5]};
       $finish;
you can change the UVM verbosity with th ewneeded verbosity with:
simulation_command +UVM_VERBOSITY=UVM_HIGH filename.sv
Code file: http://systemverilog.us/vdispvar2.sv
Results
  • SVA Handbook 4th Edition, 2016 ISBN 978-1518681448
    // For 10% discount, use code 45KJT5GN @ https://www.createspace.com/5810350
