Invoking response_handler even after seq_h.start completes
Hi Moderators,
In my AXI4 Tb there exists a sequence ‘seq’ which is created once and whenever there is a call to write or read API, seq_h.start is called
Within it’s body() task ::
 use_response_handler(1);
 req = user_seq_item::create("req",this);
 start_item(req);
 // req is randomized
 finish_item(req);
virtual function void response_handler( uvm_sequence_item response);
 // Some logic here
Note that during each call to seq.start it doesn’t wait for response
The issue with above code is even when the response is sent by Driver (via the sequencer) the response_handler is never called
On debugging the UVM Base Class Library I notice
function void uvm_sequencer_param_base::put_response (RSP t);
  sequence_ptr = m_find_sequence(t.get_sequence_id());
  if (sequence_ptr != null) begin
    // If the response_handler is enabled for this sequence, then call the response handler
    if (sequence_ptr.get_use_response_handler() == 1) begin
      sequence_ptr.response_handler(t);
      return;
    sequence_ptr.put_response(t);
Response handler is called only if m_find_sequence returns non-null
On further debugging I observe the implementation of task ‘start’ is as follows
// Within uvm_sequence_base::start
        m_sequence_state = UVM_BODY;
        #0;
        body();
        m_sequence_state = UVM_ENDED;
        #0;
        if (parent_sequence != null) begin
          parent_sequence.post_do(this);
        if (call_pre_post == 1) begin
          m_sequence_state = UVM_POST_BODY;
          #0;
          post_body();
        m_sequence_state = UVM_POST_START;
        #0;
        post_start();
        // Drop the objection if enabled
        if (get_automatic_phase_objection()) begin
           m_safe_drop_starting_phase("automatic phase objection");
        m_sequence_state = UVM_FINISHED;
        #0;
    join
    if (m_sequencer != null) begin
      m_sequencer.end_tr(this);
    // Clean up any sequencer queues after exiting; if we
    // were forcibly stoped, this step has already taken place
    if (m_sequence_state != UVM_STOPPED) begin
        m_sequencer.m_sequence_exiting(this);
    #0; // allow stopped and finish waiters to resume
    if ((m_parent_sequence != null) && (m_parent_sequence.children_array.exists(this))) begin
       m_parent_sequence.children_array.delete(this);
    old_automatic_phase_objection = get_automatic_phase_objection();
    m_init_phase_daps(1);
    set_automatic_phase_objection(old_automatic_phase_objection);
The call to function ‘m_sequence_exiting’ internally calls function ‘m_unregister_sequence’ which unregisters the sequence from the Sequencer.
Since the goal is to invoke the reponse_handler when the response is returned by the driver ( even after task ‘start’ ends ), one solution that I am thinking of is to override the virtual start task in my sequence.
In the overridden task ‘start’ I am thinking of ending the task once fork join completes
 //  Within the overriden task 'start'
        #0;
    join
 // Doesn't call the  following APIs ::
 //  m_sequencer.end_tr(this) ,
 //  m_sequencer.m_sequence_exiting(this); etc ...
    endtask:start
[1] Would this be a correct approach ?
[2] Any alternate suggestions are welcome
I suggest creating a thread using get_response() instead of ever using the response handler.
Could you please elaborate ?
Is usage of response_handler discouraged ( similar to uvm_field macros ) ?
Once the start task ends, it would end up un-registering the sequence due to following code
(irrespective of whether response_handler is active or not)
 if(m_sequence_state != UVM_STOPPED) begin
   if(m_sequencer != null)
   m_sequencer.m_sequence_exiting(this); // Called with or w/o response handler !!
Even for a case where response_handler isn’t activated
get_response unblocks when sequencer calls put_response ( via driver calling put(rsp) / item_done(rsp) )
  if(sequence_ptr != null) begin // False due to m_sequencer.m_sequence_exiting(this);
      return;
This would mean that function ‘m_find_sequence’ would return null (due to previous call to seq_h.start ending) and never call sequence_ptr.put_response ( thereby get_response(rsp) would remain blocked )
Also unlike response_handler, the start task calls the following ( b4 calling body() )
 // Check that the response queue is empty from earlier runs
 clear_response_queue(); // Results in response_queue.delete()
I would need to override this virtual task ‘clear_response_queue’ as well to not delete it (during latter calls to seq_h.start)
What if I were to assign null to m_sequencer at the end of each body() task invocation ?
  if (m_sequencer != null) // This condition would be false now
The UVM offers various ways to achieve the same result. Unless there’s a distinct advantage, I recommend adopting a single approach and enforcing it as a guideline.
It seems that both techniques face problems when the body() method returns prematurely. Do you have a good reason for wanting the body() method to return before receiving a response? Can you delay it until it gets a response?
We are trying to implement outstanding AXI writes via RAL i.e we send AWAddr & WData (single beat) without waiting for it’s BResp.
The basic idea stems from a paper suggested by you in user-defined-frontdoor-v-s-uvm-frontdoor
When using user-defined front door the UVM internally calls start for user-defined frontdoor sequence for each call to reg.write
// ...VIA USER FRONTDOOR
   if (map_info.frontdoor != null) begin
     uvm_reg_frontdoor fd = map_info.frontdoor;
     fd.rw_info = rw;
     if (fd.sequencer == null)
         fd.sequencer = system_map.get_sequencer();
      fd.start(fd.sequencer, rw.parent); // start is called for each call to write
Task ‘start’ would end as soon as finish_item(req) unblocks within body()
We want to update the mirrored value when the BResp is received
