Integer dynamic array sum constraint not working
The sum constraint is being applied. When you add large numbers, they will overflow, with the truncated result being equal to ‘sum’.
You should change your constraint:
constraint array_c { foreach(array[i]) array[i] inside {[0:sum]};}
