hi,
can someone explain why the sum constraint is not getting applied ?
class dynamic_array;
rand int array[ ];
int sum;
constraint size_c { array.size() inside {[4:10]}; }
constraint array_c { foreach(array[i]) array[i] > 0;}
constraint array_sum {array.sum() == sum;}
// array.shuffle();
function void display();
$display("array size is = %0d",array.size());
$display("sum = %0d",sum);
$display("array = %p",array);
program dynamic_array_randomization;
dynamic_array pkt;
pkt = new();
pkt.sum=100;
pkt.randomize();
pkt.display();
endprogram
array size is = 5
sum = 100
array = '{555550237, 51794743, 886026138, 2100062112, 701534166}
Why are the individual elements so huge ? their sum should be =100.
cgales
2
The sum constraint is being applied. When you add large numbers, they will overflow, with the truncated result being equal to ‘sum’.
You should change your constraint:
constraint array_c { foreach(array[i]) array[i] inside {[0:sum]};}
Please pay attention, your array elements are represented by int:
a signed 2-state variable of size 32 bits
-2^31 to 2^31-1
Do you really need such type to represent the elements?
this was a practice code for learning constraints.
class sample;
rand int arr[];
constraint arr_sum{
arr.size() == 10;
arr.sum() with (((item>0) && (item<1000))?1:0) == arr.size();
arr.sum() == 100;
function void print();
$display("array : %p | sum : %3d",arr,arr.sum());
endfunction: print
endclass: sample
module tb_top();
sample h;
h = new();
h.randomize();
h.print();
endmodule: tb_top
array : '{2, 11, 10, 20, 16, 11, 9, 7, 9, 5} | sum : 100
You definitely need to limit the maximum value of any signed element to avoid overflow and get the intended result.
