Illegal assignment mailbox error
Kindly help to resolve the basic stuff of mailbox error.
Transaction class:
class transaction;
   rand bit [7:0] data;
function void display();
      $display ("[%0t] Data = 0x%0h", $time, data);
Generator class:
class generator;
`include "transaction.sv"
   mailbox mbx;
   function new(mailbox mbx);
      this.mbx = mbx;
   task genData();
      transaction trns = new();
      void'(trns.randomize());
      void'(trns.display());
      $display ("[%0t] [Generator] Going to put data packet into mailbox", $time);
      mbx.put(trns);
      $display ("[%0t] [Generator] Data put into mailbox", $time);
driver class:
class driver;
   mailbox mbx;
      this.mbx = mbx;
   task drvData ();
      transaction drvTrns = new();
      $display ("[%0t] [Driver] Waiting for available data", $time);
      mbx.get(drvTrns);
      $display ("[%0t] [Driver] Data received from Mailbox", $time);
      void'(drvTrns.display());
tb top module:
module tb;
`include "generator.sv"
`include "driver.sv"
   mailbox mbx;
   generator Gen;
   driver    Drv;
      mbx = new();
      Gen = new(mbx);
      Drv = new(mbx);
         #5 Gen.genData();
         #10 Drv.drvData();
      join_none
It is not runnning.
What do you mean by ‘not running’? Does it compile? Does it elaborate? Does it run but give an error? Does it run but not give the results you expect?
You should provide more detail regarding your issues and design requirements.
Also, it would really help to have a minimal, complete reproducible example, preferably on EDA Playground.
Hi Cgales,
It is compiling. No syntax error. But it gives the fatal error as given below:
[0] [Driver] Waiting for available data
[10] Data = 0x50
[10] [Generator] Going to put data packet into mailbox
[10] [Generator] Data put into mailbox
** Fatal: Illegal assignment to class work.tb/work.driver::transaction from class work.tb/work.generator::transaction
Time: 10 ns Iteration: 1 Process: /tb/fork#18_4f5f3030 File: C:/questasim64_2021.1/win64/../verilog_src/std/std.sv
Fatal error in Task std/mailbox::get at C:/questasim64_2021.1/win64/../verilog_src/std/std.sv line 41
HDL call sequence:
Stopped at C:/questasim64_2021.1/win64/../verilog_src/std/std.sv 41 Task std/mailbox::get
called from driver.sv 12 Task tb/driver::drvData
called from tb.sv 18 Module tb
When you include a file inside a class, you create a specialization that doesn’t match the other classes where the file is included. You should look at the SystemVerilog LRM and use packages as appropriate.
Thanks. It is working now.
Hi Sunil
Could you pls let me know the change that made it work?
