The virtual sequencer is extended from uvm_sequencer base class.
class router_virtual_sequencer extends uvm_sequencer #(uvm_sequence_item);
`uvm_component_utils(router_virtual_sequencer)
router_env_config env_cfg;
// Source sequencer handel
router_src_sequencer src_seqrh[];
// Destination sequencer handel
router_dst_sequencer dst_seqrh[];
function new(string name = "router_virtual_sequencer", uvm_component parent);
super.new(name,parent);
if(!uvm_config_db#(router_env_config)::get(this,"","router_env_config",env_cfg))
`uvm_fatal("V_SEQRH","Getting failed in virtual sequencer check it")
dst_seqrh = new[env_cfg.no_of_dst_agent];
src_seqrh = new[env_cfg.no_of_src_agent];
endclass: router_virtual_sequencer
In my test extended class if I write in the below format what will happen…?
class router_test_extd extends router_test;
`uvm_component_utils(router_test_extd)
router_src_ext_seq src_seq;
function new(string name = "router_test_extd",uvm_component parent);
super.build_phase(phase);
task run_phase (uvm_phase phase);
src_seq = router_src_ext_seq::type_id::create("src_seq");
phase.raise_objection(this);
for(int i =0; i<no_of_src_agent;i++)
//**src_seq.start(envh.v_seqrh.src_seqrh[i]);**
**src_seq.start(envh.v_seqrh);
phase.drop_objection(this);
