I know its a basic question tried to figure but couldn’t. I am trying to write a range for wild card bins. I have written the following cover group. If we have fewer wildcard bins It would be okay to use separate bins but if we have a lot of bins lets say from 40-5F. I feel it’s not preferable to write individual wildcard bins so trying to write a range of wildcard bins from 40-5F. Any help would be appreciated. Thank you
covergroup try @(posedge clk);
verify: coverpoint {addr[14:7]}{
wildcard bins a = {8'b??11???1} // 49
wildcard bins b = {8'b?1??1?1?} //4A
wildcard bins c = {8'b?1??1?11} //4B
endgroup: try
There is no feature that allows you to specify a range of wildcards. Each wildcard is a shortcut for a set of bin values. You can create a function that builds a set of values and stores them in an array, and then specify that array as the bin set.
The ? / X / Z mentioned in the bin set itself acts as a range .
Is this why an explicit range using ? / X / Z in both lower and upper bounds isn’t valid ?
OR Are there any possible side-effects of using ? / X / Z in both lower and upper bounds ?
(2)
Would it be possible to have this explicitly mentioned in the future versions of the LRM ? The 2017 - LRM has no mention stating the same directly or indirectly .
An alternative solution to the array as bin set would be using with_clause ::
