Hi VA,
Assume we have a register in the DUT, that after a boot-sequence is configured to specific value.
We would like to check this value remines unchanged till the end of simulation.
How would you suggest to code a check/assertion for it without running the assertion each clock cycle (performance vise)?
Checking that the value is the same only in the $finish event of simulation is not enough, in-case it flipped few times during the simulation but eventually simulation ended with the register having exact value that was written to it in the boot-sequence.
Michael
As long as there are no potential glitches in the register, you could write
// wait here for boot sequence to complete
// [insert your code here]
@path_to_register assert(0) else $error("register has changed");
But if you need to look at the sampled value of the register field, there is no getting around checking each clock cycle.
Thanks for the answer.
First time I see code example like that.
Just to make sure I got the idea:
@path_to_register
Is an event which would be triggered when register.field will be modified?
@signal
waits for signal
to change its value.
