How to write functions that handle in-line constraints
Hi Dave,
Sorry for the delay. And thanks for the quick response.
Here is the sample code…
  // Types
  typedef enum {A0, A1, A2, A3, A4, A5, A6, A7, A8, A9} type_a;
  typedef enum {B0, B1, B2, B3, B4, B5, B6, B7, B8, B9} type_b;
  typedef enum {C0, C1, C2, C3, C4, C5, C6, C7, C8, C9} type_c;
  // Single element
  class myClass;
    const type_a a;
    const type_b b;
    const type_c c;
    // Some random variables based on contant fields
    rand int ar;
    rand int br;
    rand int cr;
    // Constraints linking constant fields with random variables
    constraint dummy_constraint {
      if (a == A0) ar == 'd10;
      if (b == B1) ar == 'd13;
      if (c == C2) ar == 'd20;
    // Initializes constant fields
    function new (type_a a, type_b b, type_c c);
      this.a = a;
      this.b = b;
      this.c = c;
    endfunction : new
    // Show method
    function void show;
      $display (a.name, " ", b.name, " ", c.name);
    endfunction : show
  endclass : myClass
As you see, we can have 10^3 possible combinations for variables a, b & c together, but out of them very few are actually valid, (10 in our case) enumerated below.
  // Container of queue
  class db_manager;
    const local myClass q[$];
    local myClass tmp;
    function new;
      myClass q[$];
      tmp = new(A0, B0, C0);  q.push_back(tmp);
      tmp = new(A1, B2, C1);  q.push_back(tmp);
      tmp = new(A2, B4, C3);  q.push_back(tmp);
      tmp = new(A3, B6, C5);  q.push_back(tmp);
      tmp = new(A4, B8, C7);  q.push_back(tmp);
      tmp = new(A5, B1, C9);  q.push_back(tmp);
      tmp = new(A6, B3, C2);  q.push_back(tmp);
      tmp = new(A7, B5, C4);  q.push_back(tmp);
      tmp = new(A8, B7, C6);  q.push_back(tmp);
      tmp = new(A9, B9, C8);  q.push_back(tmp);
      this.q = q;
    function show;
      foreach (q[i]) q[i].show();
    endfunction : show
  endclass : db_manager
In my case, its about few thousand valid combinations in a pool of few million possible combinations.
On top of that, I will have few random variables like ‘ar, br & cr’, that depend on ‘a, b & c’, which will have more constraints.
Hence my requirement, to search the queue with given search criteria among constant fields, and then to randomize the random fields.
Please let me know if you need any further inputs.
This time I will respond soon.
Regards,
Krishna
