How to use Virtual sequence containing different sequences running on different sequencers?
In reply to withankitgarg:
Do you have any more information as to where the error message is coming from? Are you sure it’s from the `uvm_do* macros? The message seems somewhat generic and non-identifying.
Try using the direct API calls to start your sequences and see if that helps you debug the issue.
