In reply to baladevi:
On the same hierarchy Level you can connect only ports with exports. If you are changing the level you can connect ports with ports and exports with exports.
An analysis_imp is the last in the chain of analysis exports which has to provide the write-method.
a uvm_analysis_tlm_fifo is an unbounded TLM fifo.
