HI ,
I want a scenario where UVM tests has an int variable declared. (Variable increments in the test.)
The same variable/datatype is used as a checker in the sequence once the body completes.
please let me know how to use it.
-Regards,
-RAJA.
HI ,
-Regards,
-RAJA.
Pass it as inline constraint in the sequence or assign it the same using the sequence object as follows.
class test extends uvm_test;
int v;
super.run_phase(phase);
seq = sequence1::type_id::create("sequence1");
seq.v = this.v;
seq.randomize();
seq.start( < **sequencer**>);
The solution provided by @Sabarish works if the value of the variable does not change in the test once the sequence gets started.
You can create a shared object containing the variable and share a handle to the object using the uvm_config_db
