In reply to warnerrs:
Hi Warners,
Thanks for the reply. In the link that you have sent has example where uvm components are set and get. Here I have a config variable in the test which I want to set and get the variable.
So when I set a value say 2 from the testcase, and when I do a get I should get the value 2. How can I do this using uvm_config_db set and get methods.
Thanks
