How to send data from Monitor to Sequence
////////////////////////Information from Monitor ////////////////////////////////
840000:I:uvm_test_top.chip0_mcu0.intrpt.monh: DATA FROM MON: DATA received from Interrupt MONITOR is : [0]
2520000:I:uvm_test_top.chip0_mcu0.intrpt.monh: DATA FROM MON: DATA received from Interrupt MONITOR is : [0]
19902960000:I:uvm_test_top.chip0_mcu0.intrpt.monh: DATA FROM MON: DATA received from Interrupt MONITOR is : [1]
45142440000:I:uvm_test_top.chip0_mcu0.intrpt.monh: DATA FROM MON: DATA received from Interrupt MONITOR is : [5]
45148320000:I:uvm_test_top.chip0_mcu0.intrpt.monh: DATA FROM MON: DATA received from Interrupt MONITOR is : [1]
45377640000:I:uvm_test_top.chip0_mcu0.intrpt.monh: DATA FROM MON: DATA received from Interrupt MONITOR is : [5]
45383520000:I:uvm_test_top.chip0_mcu0.intrpt.monh: DATA FROM MON: DATA received from Interrupt MONITOR is : [1]
45602760000:I:uvm_test_top.chip0_mcu0.intrpt.monh: DATA FROM MON: DATA received from Interrupt MONITOR is : [5]
45608640000:I:uvm_test_top.chip0_mcu0.intrpt.monh: DATA FROM MON: DATA received from Interrupt MONITOR is : [1]
45832920000:I:uvm_test_top.chip0_mcu0.intrpt.monh: DATA FROM MON: DATA received from Interrupt MONITOR is : [5]
45838800000:I:uvm_test_top.chip0_mcu0.intrpt.monh: DATA FROM MON: DATA received from Interrupt MONITOR is : [1]
46062240000:I:uvm_test_top.chip0_mcu0.intrpt.monh: DATA FROM MON: DATA received from Interrupt MONITOR is : [5]
46068120000:I:uvm_test_top.chip0_mcu0.intrpt.monh: DATA FROM MON: DATA received from Interrupt MONITOR is : [1]
46282320000:I:uvm_test_top.chip0_mcu0.intrpt.monh: DATA FROM MON: DATA received from Interrupt MONITOR is : [5]
46288200000:I:uvm_test_top.chip0_mcu0.intrpt.monh: DATA FROM MON: DATA received from Interrupt MONITOR is : [1]
46512480000:I:uvm_test_top.chip0_mcu0.intrpt.monh: DATA FROM MON: DATA received from Interrupt MONITOR is : [5]
46518360000:I:uvm_test_top.chip0_mcu0.intrpt.monh: DATA FROM MON: DATA received from Interrupt MONITOR is : [1]
46737600000:I:uvm_test_top.chip0_mcu0.intrpt.monh: DATA FROM MON: DATA received from Interrupt MONITOR is : [5]
46743480000:I:uvm_test_top.chip0_mcu0.intrpt.monh: DATA FROM MON: DATA received from Interrupt MONITOR is : [1]
46967760000:I:uvm_test_top.chip0_mcu0.intrpt.monh: DATA FROM MON: DATA received from Interrupt MONITOR is : [5]
46973640000:I:uvm_test_top.chip0_mcu0.intrpt.monh: DATA FROM MON: DATA received from Interrupt MONITOR is : [1]
47197920000:I:uvm_test_top.chip0_mcu0.intrpt.monh: DATA FROM MON: DATA received from Interrupt MONITOR is : [5]
47203800000:I:uvm_test_top.chip0_mcu0.intrpt.monh: DATA FROM MON: DATA received from Interrupt MONITOR is : [1]
47423040000:I:uvm_test_top.chip0_mcu0.intrpt.monh: DATA FROM MON: DATA received from Interrupt MONITOR is : [5]
47428920000:I:uvm_test_top.chip0_mcu0.intrpt.monh: DATA FROM MON: DATA received from Interrupt MONITOR is : [1]
50150631000:I:uvm_test_top.chip0_mcu0.intrpt.monh: interrupt_mon: Interrupt Entering into Monitor
////////////////////////From Sequence
21930630000:I:m_sequencer@@interrupt_sequence: DATA FROM Mon_Seq: DATA received from RX MONITOR is : [0]
21940630000:I:m_sequencer@@interrupt_sequence: DATA FROM Mon_Seq: DATA received from RX MONITOR is : [0]
21950630000:I:m_sequencer@@interrupt_sequence: DATA FROM Mon_Seq: DATA received from RX MONITOR is : [1]
only 2 transactions only im able to get into the sequence, can you please tell me why remaining transfers are not coming to sequence
