How to retrieve the correct values of continuously driven values of DUT in the test bench
Hello people,
I am Sai Kumar, and I am working on a project of FIFO to learn about the System Verilog test bench flow. I need to get the values of two signals which are empty and full which are driven continuously in the DUT how to calculate their exact values at the moment of those Values in the reference model.
What are the steps I need to follow in the test bench since i cannot use assign statement in my Reference model, since it is a class.
I hope you understand my query and reply to me with the suitable suggestion
Thank you
The explanation isn’t that clear, but if you’re asking about how to connect the testbench to DUT, assuming it is a class-based, then the most common way is using SystemVerilog virtual interfaces even though there might be other ways.
If you just started, I recommend reading this very nice paper by Dave The missing link: The Testbench to DUT Connection
