Hi experts,
What I want to achieve:
I want to create variable number of streams in my testcase. In hw_top.sv file maximum number of stream interfaces are always created and connected to DUT.
In UVM classes, only needed number of streams are created. Thus number of uvm_config_StreamIf::set calls are needed.
I want to pass value containing number of created streams from UVM class (uvm_test_top) to tb_top (which controls interface assignements to virtual interface fields in UVM classes).
What I have currently:
My current approach can be summarized with following snippet:
// Inside of uvm_test_top:
rand unsigned int num_streams;
// File tb_top.sv:
int num_streams;
// uvm_config_get call was here but it didn't work
// Currently I fixed this value to maximum and I am stuck with unread factory overrides for not created streams
num_streams = 64;
for (int i = 0; i < num_streams; ++i) begin
set_stream_ctrl_if(i);
run_tests();
function void set_stream_ctrl_if(int index);
string name;
name = $sformatf("*.tb.env_stream[%0d].agent.*", index);
case (index)
0 : uvm_config_StreamIf::set(null, name, "vif", hw_top.stream_if_0);
1 : uvm_config_StreamIf::set(null, name, "vif", hw_top.stream_if_1);
// The rest of interfaces + default
endcase
// File hw_top:
StreamIf stream_if_0 (.clk(clk), .rstn(rst_n));
StreamIf stream_if_1 (.clk(clk), .rstn(rst_n));
// and the rest of interfaces + DUT
What is the issue with current approach
I have an issue with execution in correct order. When using uvm_config_db#(bit)::get the read was before uvm_test_top written value to database. I tried to use uvm_config_db#(bit)::wait_modified but this makes build process fail - build process advances to creation of drivers and monitors before any interface is set to override virtual interface.
I also searched for ways to access uvm_test_top from tb_top. I only found information that it is not possible.
What I need help with
I would like to know if it is possible to put that in correct order.
- Write value to database (from uvm_test_top),
- Read that value in tb_top,
- Call uvm_config_db#(bit)::set functions,
- Build all following classes under uvm_test_top.
If there is another (better) approach to this situation, please let me know.
If this description is not clear, please tell me what needs more details - I will try to fix it.
Thank you for your help (in advance)
