I wanted to override one instance of NOC_base to Agent and remaining two instances to fabric. How can I achieve this?
You can override all instances by type, and then override the specific instance by inst. Here is an example.
`include "uvm_macros.svh"
import uvm_pkg::*;
class base extends uvm_component;
`uvm_component_utils(base);
function new(string name,uvm_component parent);
super.new(name,parent);
uvm_report_info(get_type_name(),"build");
class agent extends base;
`uvm_component_utils(agent);
class fabric extends base;
`uvm_component_utils(fabric);
class env extends uvm_env;
`uvm_component_utils(env);
base base_[4];
foreach(base_[i])
base_[i] = base::type_id::create($sformatf("base_%0d_",i),this);
class test extends uvm_test;
`uvm_component_utils(test);
env env_;
set_type_override_by_type(base::get_type(), agent::get_type());
set_inst_override_by_type("env_.base_3_", base::get_type(), fabric::get_type());
env_ = env::type_id::create("env_",this);
run_test("test");
Thankyou so much dave_59. This worked
Can’t we use just set_inst_override_by_type for all instances?
Type override is much more efficient–no dealing with regular expression matching in strings. Plus you have to worry about the ordering of inst overrides, and there is no way to remove/replace an inst override.
