How to Make an array of extended class (a list of test)
In reply to jflarin:
SystemVerilog has syntax to do exactly this using the class scope operator.
array_of_test[0] = Test0001::new(cpu);
array_of_test[1] = Test0002::new(cpu);
array_of_test[2] = Test0003::new(cpu);
You will also need to make the run task a pure virtual method in your base class.
virtual class CTest;
    string name;
    virtual cpu_if zcpu; // l'interface CPU
    function new(string name, virtual cpu_if zcpu);
        this.name       = name;
    task processor_startup; // common to all tests
    pure virtual task run;
endclass : CTest
This virtual class CTest is not allowed to be constructed directly, and any extension to it must define a run task.
