How to integrate the interface of AHB VIP into SoC level?
In reply to Have_A_Doubt:
To facilitate reuse, the following requirements should be used:
  • Each agent shall have a corresponding configuration object which contains the handle to the required virtual interface.
  • Each environment shall have a corresponding environment configuration object which contains the required agent configuration object(s).
  • Each environment will use the config_db to retrieve it’s configuration object. The environment will then utilize the config_db to pass the agent’s configuration object to the agent.
  • Any upper-level environment configuration object will contain sub-environment configuration objects.
To use this structure:
  • The top-level TB instantiates all required interfaces and connects them to the DUT at the appropriate locations (direct port connections, assigns, bind statements, etc).
  • The top-level TB adds all interfaces to the config_db, using a unique name for each instance and targeting ‘uvm_test_top’.
  • The test will create the top-level environment configuration object, which will recursively create all sub-configuration objects.
  • The test will retrieve all interface handles into each agent’s configuration object.
  • The test will use the config_db to pass the environment configuration to the environment.
  • The environment will retrieve it’s configuration object and in turn pass the sub-environment or agent configuration objects as required.
