I did the following:
// tx_fe forces and assignments
assign tx_vif.cyc_tic = dut.tx_fe.cyc_tic_internal;
start_of_simulation_ph.wait_for_state(UVM_PHASE_STARTED);
if(!uvm_config_db #(tx_agent_config)::get(null, "uvm_test_top.env", "db_tx_agent_config", m_tx_cfg)) begin
`uvm_error("top", "tx_agent_config not found")
end//if
if (m_tx_cfg.is_active == UVM_ACTIVE) begin
force dut.tx_fe.xi_n = tx_vif.xi;
force dut.tx_fe.xq_n = tx_vif.xq;
// rx_fe forces and assignments
assign rx_vif.chind2 = dut.rx_fe.chind2;
if(!uvm_config_db #(rx_agent_config)::get(null, "uvm_test_top.env", "db_rx_agent_config", m_rx_cfg)) begin
`uvm_error("top", "rx_agent_config not found")
end//if
if (m_rx_cfg.is_active == UVM_ACTIVE) begin
force dut.rx_fe.x = rx_vif.x;
I got error when I try to run this:
UVM_ERROR …/sv/girobo2_tb_top.sv(175) @ 0: reporter [top] rx_agent_config not found
