Dear All,
Currently I’m learning the coverage. It’s very powerful methods for verification I think.
But I’v got a problem that I’m trying to get a non-duplicated randomized value .
Here is the code.
class packet;
rand bit[4:0] img_index;
rand bit[31:0] crop_seed;
constraint const_img_index
(img_index >= 0 && img_index <= 4);javascript:void(0)
img_index dist {[0:4] :/ 1};
constraint const_crop_seed
crop_seed dist {[0:4] :/ 1};
covergroup img_src;
img_idx : coverpoint img_index {
bins b_0 = {32'h0};
bins b_1 = {32'h1};
bins b_2 = {32'h2};
bins b_3 = {32'h3};
crop_seed : coverpoint crop_seed {
bins b_0 = {32'h0};
bins b_1 = {32'h1};
bins b_2 = {32'h2};
bins b_3 = {32'h3};
CROSS: cross img_idx, crop_seed;
endgroup
module constr_dist;
packet pkt;
pkt = new();
$display("------------------------------------");
foreach(pkt.img_index[i]) begin
pkt.randomize();
$display("\const_img_index = %0d",pkt.img_index);
I got the duplicated randomized value from the codes the below.
const_img_index = 1
const_img_index = 1
const_img_index = 0
const_img_index = 0
const_img_index = 0
How to get non-duplicate randomized values? I expected that
const_img_index has 5 values from 0 to 4. but the same value come out.
If all bins don’t hit, I want to keep running randomize until all bins hits. Is there any possible way to get this method?
SIM: coverage distribute(1) - EDA Playground
cgales
March 11, 2021, 9:03pm
2
In reply to UVM_LOVE :
Randomizing only 5 times does not give a representative distribution. If you randomize more, you will see the results you expect:
module constr_dist;
packet pkt;
pkt = new();
repeat (50) begin
if (!pkt.randomize()) $display("Randomization error");
else $display("const_img_index = %0d",pkt.img_index);
Also, you don’t instantiate your covergroup anywhere, nor sample it, so you aren’t generating any coverage metrics.
endgroup
function new();
img_src = new();
module constr_dist;
packet pkt;
pkt = new();
while(pkt.img_src.img_idx.get_inst_coverage() != 100) begin
//while(pkt.img_src.get_inst_coverage() != 100) begin
pkt.randomize();
pkt.img_src.sample();
In reply to Hiren Solanki :
endgroup
function new();
img_src = new();
module constr_dist;
packet pkt;
pkt = new();
pkt.randomize();
Would you please let me know any special reason you used get_inst_coverage instead of using get_coverage ?
get_inst_coverage works the same as get_coverage if the per_instance option is zero or there is just one instance of that covergroup.
hsam
March 17, 2021, 7:22pm
6
Dear All,
Here is the code.
class packet;
covergroup img_src;
bins b_0 = {32'h0};
bins b_1 = {32'h1};
bins b_2 = {32'h2};
bins b_3 = {32'h3};
bins b_0 = {32'h0};
bins b_1 = {32'h1};
bins b_2 = {32'h2};
bins b_3 = {32'h3};
endgroup
module constr_dist;
packet pkt;
pkt = new();
pkt.randomize();
const_img_index = 1
const_img_index = 1
const_img_index = 0
const_img_index = 0
const_img_index = 0
You can also change rand to randc (cyclic rand) which won’t repeat the duplicate values.
Also we have to remove the dist usage if we switch to randc and your constraint should look like this. I tried it in eda playground by copying your code and making the edits mentioned and it works as expected.
randc bit[4:0] img_index;
