How to define transaction class when I used parameterized interface?
In reply to aluowell:
Hi,
I’m writting a VIP used parameterized interface. The address width of interface is configurable.
I learned the chapter ParameterizedTests in UVM Cookbook and implemented the parameterized interface by using config_db API.
But the question is how to define transaction class ? Because the address width is configurable. It seems the driver couldn’t be reused.
like:
module top;
a_bus#(.addr_width(4)) bus0;
a_bus#(.addr_width(8)) bus1;// or 16,32,64 width
class bus_driver extends uvm_driver#(bus_transaction);
virtual a_bus v_a_bus;
function void run_phase(phase);
bus_transaction bus_tr;
v_a_bus <= bus_tr.addr;
class bus_transaction extend uvm_sequence_item;
logic[3:0] addr;//if I define like this,this VIP can’t reused by other address width
// or define like logic[7:0] addr;
// but it’s not flexible
So how to define the transaction class can be flexible ?
I would not define the interface and the transaction parameterized. Put your parameters in a package, like DATA_WIDTH0 = 8, DARA_WIDTH1=16, etc. In each place you need these parameters import the corresponding package. Than all things are fine.
