How to copy memory content from one address location to other location using SV Function /Dont use temporary variable use while copying?
I am trying to copy the memory address content from [0th- 4th] location to [3th -7th] address location . Need not use temporary variable while copying . I see there is overap for 6th and 7th location copied data and its incorrect data . How to fix this issue ? can we use NBA assignment /Fork_join concept to do that ? if yes how to do ?
Current Output
run -all
# Mem[          0] = 17750c26
# Mem[          1] = 9d0db966
# Mem[          2] = bcb9e3b6
# Mem[          3] = 510e08c6
# Mem[          4] = 83956e46
# Mem[          5] = 3bd10f72
# Mem[          6] = 769bf32e
# Mem[          7] = fa374467
# Mem[          8] = 3386553a
# Mem[          9] = 46f91c6a
# After copying - Mem[          0] = 17750c26
# After copying - Mem[          1] = 9d0db966
# After copying - Mem[          2] = bcb9e3b6
# After copying - Mem[          3] = 17750c26
# After copying - Mem[          4] = 9d0db966
# After copying - Mem[          5] = bcb9e3b6
# After copying - Mem[          6] = 17750c26
# After copying - Mem[          7] = 9d0db966
# After copying - Mem[          8] = 3386553a
# After copying - Mem[          9] = 46f91c6a
# Copy content of memory locations from one address to another address without using temp variables
SV Code -
class copy_memory ;
parameter DEPTH = 10 ;
logic [31:0] mem[DEPTH];
task swap( logic [31:0] addr_src , logic [31:0] addr_dest , logic [31:0] size );
// Intialise the memory
for (int i=0 ; i< DEPTH ; i++) begin
mem[i] = $urandom();
$display("Mem[%d] = %h ",i,mem[i]);
for (int i=0 ; i< size ; i++) begin
mem[addr_dest] = mem[addr_src] ;
addr_dest++;
addr_src++;
$display("After copying - Mem[%d] = %h ",i,mem[i]);
module mem_model ;
copy_memory mem_h;
mem_h = new();
mem_h.swap(0,3,5) ;
$display ("Copy content of memory locations from one address to another address without using temp variables ");
```verilog
Using NBAs would solve your problem if you do not need the results in the same time step. Otherwise you will need to test for an overlap requiring copying in reverse order.
if(addr_src < addr_dest && addr_src + size >= addr_dest) begin
   addr_dest += size;
   addr_src += size;
      repeat(size)
        mem[--addr_dest] = mem[--addr_src] ;
else begin
      repeat(size)
        mem[addr_dest++] = mem[addr_src++] ;
Thanks @dave_59 . your solution works fine when we want to mem copy to happen at the same timestamp .
I have also tried using NBA and I see there is no overlap happening for mem locations. Pasting code as below -
using NBA assignments Logic -
        for (int i=0 ;i<size ;i++)  begin
          mem[addr_dest+i] <= mem[addr_src+i] ;
   join
  #1 ;
Output -
> KERNEL: Mem[          0] = 005444e2
> KERNEL: Mem[          1] = 5d205fad
> KERNEL: Mem[          2] = 6d8bf378
> KERNEL: Mem[          3] = 34d69016
> KERNEL: Mem[          4] = fdd88f7b
> KERNEL: Mem[          5] = 24431c11
> KERNEL: Mem[          6] = ef29a6e3
> KERNEL: Mem[          7] = b2b609ae
> KERNEL: Mem[          8] = cd3f19b8
> KERNEL: Mem[          9] = 934e9689
> KERNEL: After copying - Mem[          0] = 005444e2
> KERNEL: After copying - Mem[          1] = 5d205fad
> KERNEL: After copying - Mem[          2] = 6d8bf378
> KERNEL: After copying - Mem[          3] = 005444e2
> KERNEL: After copying - Mem[          4] = 5d205fad
> KERNEL: After copying - Mem[          5] = 6d8bf378
> KERNEL: After copying - Mem[          6] = 34d69016
> KERNEL: After copying - Mem[          7] = fdd88f7b
> KERNEL: After copying - Mem[          8] = cd3f19b8
> KERNEL: After copying - Mem[          9] = 934e9689
