How to combine coverpoints
Hi, I have a simple question but can’t seem to find a straightforward answer from looking at other related questions. I have several coverpoints defined with their own bins and I just want to know how to create a new coverpoint that is the equivalent of a combined version of all the other coverpoints. I have listed an example below:
cp_1 : coverpoint (opcode)
   bins cp_1_opcode_1 = {some_value};
   bins cp_1_opcode_2 = {some_value};
   bins cp_1_opcode_3 = {some_value};
cp_2 : coverpoint (opcode)
   bins cp_2_opcode_1 = {some_value};
   bins cp_2_opcode_2 = {some_value};
   bins cp_2_opcode_3 = {some_value};
cp_3 : coverpoint (opcode)
   bins cp_3_opcode_1 = {some_value};
   bins cp_3_opcode_2 = {some_value};
   bins cp_3_opcode_3 = {some_value};
cp_total : what should I put here?
cp_total_equivalent : coverpoint (opcode)
I want to be able to cross the total as well as separate coverpoints with other coverpoints with minimum code, e.g.,
cp_cross_example_1 : cross cp_1, some_other_cp_1;
cp_cross_example_2 : cross cp_total, some_other_cp_2;
In reply to atashinchi:
You can use a combination of ‘bin set’ expressions and ‘bin with’ expressions
  int set1[] = {1,2,3};
  int set2[] = {4,5,6};
  int set3[] = {7,8,9};
  int opcode;
  covergroup cg;
    cp_1 : coverpoint opcode {
      bins cp_1_opcode[] = set1;
    cp_2 : coverpoint opcode {
      bins cp_2_opcode[] = set2;
    cp_3 : coverpoint opcode {
    cp_total : coverpoint opcode {
      bins cp_total_opcode[] = cp_total with (item inside {set1,set2,set3});
  endgroup
See sections 19.5.1.1 Coverpoint bin with covergroup expressions and 19.5.1.2 Coverpoint bin set covergroup expressions
Hi Dave ,
Is the coverpoint label restricted to be used within the following 2 cases only ? :
  1. The same coverpoint ( Eg : cover_point_identifier with ( with_covergroup_expression ) )
  2. cross bin ( via binsof( cp_label ) … )
I tried using it within a different coverpoint of same covergroup , however I observe a compilation error .
  enum  { SUB , ADD , MUL , DIV , POWER_OF }  opcode ;
   covergroup  cg ;
   bins substract = { SUB };
   bins addition  = { ADD };
  bins multiply = { MUL };
  bins divide   = { DIV };
  bins powerof = { POWER_OF };
  bins  sub   = cp_1  with  (  item  inside  { SUB }  );
  bins  add   = cp_1  with  (  item  inside  { ADD }  );
  bins  mul   = cp_2  with  (  item  inside  { MUL }  );
  bins  div   = cp_2  with  (  item  inside  { DIV }  );
  bins  power = cp_3  with  (  item  inside  { POWER_OF }  );
   endgroup
Within coverpoint cp_total_equivalent if I replace labels cp_1 , cp_2 and cp_3 with cp_total_equivalent , it works
