In reply to cuonghle:
Thanks for the answer.
I think my example is not good one because of that you got confused.
So we have a VIP from vendor, in that VIP there is a predefined callbacks with their methods.
When some event happens in the system, than that callback triggers a function. That function proto is following:
virtual function void CompletionQueueEnterCbF (vendorTrans trans);
now vendorTrans is coming together with the VIP, but I want to change that to myTrans type.
I cannot edit the CompletionQueueEnterCbF function definition as it is VIP files.
I tried to mimic this scenario using the example. In that example assume that
function monitorTraffic( trans t1);
is vendor function
