Hi Ben,
I have following question to how to execute a property making it generic and calling it n number of times in for loop so that we can cover for all registers in different hierrachy.
`define PHY_A_REG_(num) top.a.b_``num``.c.r_reg_a
`define PHY_B_REG_(num) top.a.b_``num``.c.r_reg_b
`define PHY_C_REG_(num) top.a.b_``num``.c.r_reg_c
`define PHY_D_REG_(num) top.a.b_``num``.c.r_reg_d
This four registers of PHY type has 11 variations so num
does it for them.
`define IOB_A_REG_(num) top.a.b.c.d.e.f_pair``num``_regs.r_reg_a
`define IOB_B_REG_(num) top.a.b.c.d.e.f_pair``num``_regs.r_reg_b
`define IOB_C_REG_(num) top.a.b.c.d.e.f_pair``num``_regs.r_reg_c
`define IOB_D_REG_(num) top.a.b.c.d.e.f_pair``num``_regs.r_reg_d
property kNpi_register_check_all(clk_npi, a,b,c,d);
@(posedge clk)
$fell(a) |-> ##[16245:16246] (b==0) && (c==1) && (d==0);
assert_npi_register_nibble0_checking_all : assert property (kNpi_register_check_all(top.b.c.clk,`PHY_A_REG_(1),`PHY_B_REG_(1),`PHY_C_REG_(1),`PHY_D_REG_(1)))
else `ASSERT_ERROR ("Assertion check pattern error","ALERT: global signalsa not follwing the pattern")
assert_npi_register_nibble0_checking_all : assert property (kNpi_register_check_all(top.b.c.clk,`PHY_A_REG_(10),`PHY_B_REG_(10),`PHY_C_REG_(10),`PHY_D_REG_(10)))
assert_npi_register_nibbleiob1_checking_all : assert property (kNpi_register_check_all(top.b.c.clk,`IOB_A_REG_(1),`IOB_B_REG_(1),`IOB_C_REG_(1),`IOB_D_REG_(1)))
hierarachy 1:(PHY) same four reg have 11 variations:44
hireachy 2:(IOB) has 3 variations with same reg name
can we assert the property in for loop as we need to call each unique one 47 times can we add for loop to make it unique
If yes then how
