In reply to irshad_mansur123:
You can use a packed union to access a structure a number of different ways.
union packed {
struct packed {
int a;
int b;
int c;
int d; ..... till int z;
} as_struct;
bit [1:26] [31:0] as_array;
} a2z;
Then a2z.as_struct.x and a2z.as_array[24] refer too the same set of 32-bits. Note that when you define an array, each element has to be the same type/width. In this case it only works if all members of packed struct are the same width.
