In reply to svq:
Yes, in last transaction after_txn come first and before_queue has not entry compare_data won’t execute and forever loop again block at after_fifo.get().
Btw, you can add wait after fifo like below.
forever begin
after_fifo.get (after_txn); // this is an uvm tlm analysis fifo which is getting the output txn from dut via monitor)
// We are make sure before_queue transaction is available before compare.
wait (before_queue.size > 0);
// before_queue is populated by a uvm_tlm_analysis_imp port's write methode when it receives packet from input monitor
//if (before_queue.size())
compare_data();
And 1 more thing, if before_queue is used for expected data and after_fifo used for actual data.
Then, I think you need to check your TB because expected data must arrive before actual data.
If it not the case, you can simply wait for before_queue has entry ( like above code ).
Thanks!
