How statements connect to the event scheduler, race condition time
The LRM has as an example, this piece of code and text for race conditions. It seems to me still unclear how it interacts with the event scheduling.
I tried to map the code to the scheduler =>
first delta cycle:
1. assign p = q;
2. q = 1;
both get put into the active region. The net update gets scheduled for p when a change of q takes place, this creates an event and it gets puts into the inactive region…
so then q =1, then p = 1. everyone seems happy.
for the next delta cycle:
while all the 3 statements get put into the active region( the 2 red arrows and the 1 green arrow)
maybe this is wrong but the expectation is still that because the “initial begin{ }end” is one process, it gets put together into the active region, and then it processes through these statements in order, as these are blocking statements inside the begin end. so:
execution order
  1. q = 0; // this statement causes a change in q and thus schedules p = 0, for the inactive region.
  2. $display(p); // this should display p =1, because p has not changed yet as p=0 is scheduled for later;
I have tested this and 3/4 simulators show p = 1 from the $display task.
Why is there a race condition here? The order seems known?
From the text it seems to indicate that the “update event” of q also gets put into the first active region together with display?? is it really not put into the inactive region?
q=0; gets scheduled in the active region of timestep 1. All procedural statements here get executed in the active region. Even if you changed the #1 to #0, the blocking assignment statement still occurs in the active region.
Although the statements between the begin and end keywords represent a single process, each statement is an independent active event. The non-determinism arises because the order of events between different processes executing within the same event region creates a race condition.
This non-determinism provides several benefits to simulation:
  • It allows your design to be executed on a multi-core/multi-CPU platform, which is actually much closer to the actual hardware representation.
  • It enables optimizations in software that combine multiple processes into a single process. (it could choose to update p only as q gets updated.
  • it could combine p and q variables into a single representation.
