Hi, team.
constraint en_c { solve en before val;
if(en == 1) { val inside {[0:100]} } ;}
constraint en_c1 { solve en before val1;
!(en == 1) || { val1 inside {[0:100]} } ;}
I found that these two constraints working same, can anyone explain me how’s it working.
Thank you
All constraints get broken down into a set of Boolean equations that must evaluate to a non-zero result (that’s how SystemVerilog defines true). Although the if constraint seems like a procedural construct, it actually gets converted into the boolean equation you see in en_c1
Thanks Dave, Explanation indeed helped me to understand the logic how constraints work.
but, i have this doubt. Please check with this.
case1:
but in this case only if my en==1, constraint is applied to the val, if en==0 it will not work.
case2:
here
1)if en==1
!(en==1), which it evaluates to 0, which means constraint shouldn’t work right?
2) if en==0
!(en==1) evaluates to 1, which means now constraint should be applicable right?
Is it like this || { val1 inside {[0:100]} } ;} part of the constraint always be True ?
Thank you
It might help if you built a truth table for each constraint, and shorten val to 2-bits and the range to [0:1]. Then you will see that the valid solutions (marked with a T) are the same for both constraints.
en_c { if(en == 1) { val inside {[0:1]} } ;}
en_c1 { !(en == 1) || val inside {[0:1]} } ;}
| en |
val |
en_c |
en_c1 |
| 0 |
0 |
T |
T |
| 0 |
1 |
T |
T |
| 0 |
2 |
T |
T |
| 0 |
3 |
T |
T |
| 1 |
0 |
T |
T |
| 1 |
1 |
T |
T |
| 1 |
2 |
F |
F |
| 1 |
3 |
F |
F |
Thank you Dave. Truth table made it simple.
