How are the conditions in an illegal_bin declaration handled? Or are they valid at all in the first place?
It looks to me that the illegal_bindeclaration does not consider any condition in the bins coverpoint_range_list i.e. the declaration
illegal_bins invalid_1 = {[0:7]} iff (base == 1600 && basediv == 2);
is same as
illegal_bins invalid_1 = {[0:7]};
The intention of the illegal_bin is that whenever base is 1600 and basediv is 2, any value inside [0:7] of the coverpoint expression is not a valid value.
Is there a way to code illegal_bins with conditions other than using the cross and binsof … intersect way ?
Below is the sample code.
class base_cfg;
// Divider Values
rand struct {
rand bit [ 1: 0] BaseDiv1;
rand bit [ 2: 0] BaseDiv2;
rand bit BaseDiv3;
rand bit BaseDiv4;
} s_basediv;
rand int BaseVal;
constraint c_BaseX {
BaseVal inside {1600, 1400, 1200, 1000, 800};
constraint c_basediv {
s_basediv.BaseDiv1 inside {[0: 3]};
s_basediv.BaseDiv2 inside {[0: 7]};
s_basediv.BaseDiv3 inside {[0: 1]};
s_basediv.BaseDiv4 inside {[0: 1]};
if (BaseVal == 1600) { s_basediv.BaseDiv1 inside {[0:3]}; }
if (BaseVal == 1400) { s_basediv.BaseDiv1 inside {[0:2]}; }
if (BaseVal == 1200) { s_basediv.BaseDiv1 inside {[0:2]}; }
if (BaseVal == 1000) { s_basediv.BaseDiv1 inside {[0:2]}; }
if (BaseVal == 800 ) { s_basediv.BaseDiv1 inside {[0:2]}; }
if (BaseVal == 1600 && s_basediv.BaseDiv1 == 0) { s_basediv.BaseDiv2 inside {[0:7]}; }
if (BaseVal == 1600 && s_basediv.BaseDiv1 == 1) { s_basediv.BaseDiv2 inside {[0:7]}; }
if (BaseVal == 1600 && s_basediv.BaseDiv1 == 2) { s_basediv.BaseDiv2 inside {[0:3]}; }
if (BaseVal == 1600 && s_basediv.BaseDiv1 == 3) { s_basediv.BaseDiv2 inside {[0:1]}; }
if (BaseVal == 1400 && s_basediv.BaseDiv1 == 0) { s_basediv.BaseDiv2 inside {[0:7]}; }
if (BaseVal == 1400 && s_basediv.BaseDiv1 == 1) { s_basediv.BaseDiv2 inside {[0:6]}; }
if (BaseVal == 1400 && s_basediv.BaseDiv1 == 2) { s_basediv.BaseDiv2 inside {[0:2]}; }
if (BaseVal == 1400 && s_basediv.BaseDiv1 == 3) { s_basediv.BaseDiv2 inside {[0:6]}; }
if (BaseVal == 1200 && s_basediv.BaseDiv1 == 0) { s_basediv.BaseDiv2 inside {[0:7]}; }
if (BaseVal == 1200 && s_basediv.BaseDiv1 == 1) { s_basediv.BaseDiv2 inside {[0:5]}; }
if (BaseVal == 1200 && s_basediv.BaseDiv1 == 2) { s_basediv.BaseDiv2 inside {[0:2]}; }
if (BaseVal == 1000 && s_basediv.BaseDiv1 == 0) { s_basediv.BaseDiv2 inside {[0:7]}; }
if (BaseVal == 1000 && s_basediv.BaseDiv1 == 1) { s_basediv.BaseDiv2 inside {[0:4]}; }
if (BaseVal == 1000 && s_basediv.BaseDiv1 == 2) { s_basediv.BaseDiv2 inside {[0:1]}; }
if (BaseVal == 800 && s_basediv.BaseDiv1 == 0) { s_basediv.BaseDiv2 inside {[0:7]}; }
if (BaseVal == 800 && s_basediv.BaseDiv1 == 1) { s_basediv.BaseDiv2 inside {[0:3]}; }
if (BaseVal == 800 && s_basediv.BaseDiv1 == 2) { s_basediv.BaseDiv2 inside {[0:1]}; }
if (BaseVal == 1600 && s_basediv.BaseDiv1 == 0) { s_basediv.BaseDiv3 inside {[0:1]}; }
if (BaseVal == 1600 && s_basediv.BaseDiv1 == 1) { s_basediv.BaseDiv3 inside {[0:1]}; }
if (BaseVal == 1600 && s_basediv.BaseDiv1 == 2) { s_basediv.BaseDiv3 inside {[0:1]}; }
if (BaseVal == 1600 && s_basediv.BaseDiv1 == 3) { s_basediv.BaseDiv3 inside {[0:0]}; }
if (BaseVal == 1400 && s_basediv.BaseDiv1 == 0) { s_basediv.BaseDiv3 inside {[0:1]}; }
if (BaseVal == 1400 && s_basediv.BaseDiv1 == 1) { s_basediv.BaseDiv3 inside {[0:1]}; }
if (BaseVal == 1400 && s_basediv.BaseDiv1 == 2) { s_basediv.BaseDiv3 inside {[0:1]}; }
if (BaseVal == 1200 && s_basediv.BaseDiv1 == 0) { s_basediv.BaseDiv3 inside {[0:1]}; }
if (BaseVal == 1200 && s_basediv.BaseDiv1 == 1) { s_basediv.BaseDiv3 inside {[0:1]}; }
if (BaseVal == 1200 && s_basediv.BaseDiv1 == 2) { s_basediv.BaseDiv3 inside {[0:1]}; }
if (BaseVal == 1000 && s_basediv.BaseDiv1 == 0) { s_basediv.BaseDiv3 inside {[0:1]}; }
if (BaseVal == 1000 && s_basediv.BaseDiv1 == 1) { s_basediv.BaseDiv3 inside {[0:1]}; }
if (BaseVal == 1000 && s_basediv.BaseDiv1 == 2) { s_basediv.BaseDiv3 inside {[0:0]}; }
if (BaseVal == 800 && s_basediv.BaseDiv1 == 0) { s_basediv.BaseDiv3 inside {[0:1]}; }
if (BaseVal == 800 && s_basediv.BaseDiv1 == 1) { s_basediv.BaseDiv3 inside {[0:1]}; }
if (BaseVal == 800 && s_basediv.BaseDiv1 == 2) { s_basediv.BaseDiv3 inside {[0:0]}; }
if (BaseVal == 1600 && s_basediv.BaseDiv1 == 0) { s_basediv.BaseDiv4 inside {[1:1]}; }
if (BaseVal == 1600 && s_basediv.BaseDiv1 == 1) { s_basediv.BaseDiv4 inside {[0:1]}; }
if (BaseVal == 1600 && s_basediv.BaseDiv1 == 2) { s_basediv.BaseDiv4 inside {[0:1]}; }
if (BaseVal == 1600 && s_basediv.BaseDiv1 == 3) { s_basediv.BaseDiv4 inside {[0:1]}; }
if (BaseVal == 1400 && s_basediv.BaseDiv1 == 0) { s_basediv.BaseDiv4 inside {[1:1]}; }
if (BaseVal == 1400 && s_basediv.BaseDiv1 == 1) { s_basediv.BaseDiv4 inside {[0:1]}; }
if (BaseVal == 1400 && s_basediv.BaseDiv1 == 2) { s_basediv.BaseDiv4 inside {[0:1]}; }
if (BaseVal == 1400 && s_basediv.BaseDiv1 == 3) { s_basediv.BaseDiv4 inside {[0:0]}; }
if (BaseVal == 1200 && s_basediv.BaseDiv1 == 0) { s_basediv.BaseDiv4 inside {[1:1]}; }
if (BaseVal == 1200 && s_basediv.BaseDiv1 == 1) { s_basediv.BaseDiv4 inside {[0:1]}; }
if (BaseVal == 1200 && s_basediv.BaseDiv1 == 2) { s_basediv.BaseDiv4 inside {[0:1]}; }
if (BaseVal == 1200 && s_basediv.BaseDiv1 == 3) { s_basediv.BaseDiv4 inside {[0:0]}; }
if (BaseVal == 1000 && s_basediv.BaseDiv1 == 0) { s_basediv.BaseDiv4 inside {[1:1]}; }
if (BaseVal == 1000 && s_basediv.BaseDiv1 == 1) { s_basediv.BaseDiv4 inside {[0:1]}; }
if (BaseVal == 1000 && s_basediv.BaseDiv1 == 2) { s_basediv.BaseDiv4 inside {[0:1]}; }
if (BaseVal == 1000 && s_basediv.BaseDiv1 == 3) { s_basediv.BaseDiv4 inside {[0:0]}; }
if (BaseVal == 800 && s_basediv.BaseDiv1 == 0) { s_basediv.BaseDiv4 inside {[0:1]}; }
if (BaseVal == 800 && s_basediv.BaseDiv1 == 1) { s_basediv.BaseDiv4 inside {[0:1]}; }
if (BaseVal == 800 && s_basediv.BaseDiv1 == 2) { s_basediv.BaseDiv4 inside {[0:1]}; }
if (BaseVal == 800 && s_basediv.BaseDiv1 == 3) { s_basediv.BaseDiv4 inside {[0:0]}; }
$display($psprintf("BaseVal = %d", BaseVal));
$display($psprintf("BaseDiv1 = %d", s_basediv.BaseDiv1));
$display($psprintf("BaseDiv2 = %d", s_basediv.BaseDiv2));
$display($psprintf("BaseDiv3 = %d", s_basediv.BaseDiv3));
$display($psprintf("BaseDiv4 = %d", s_basediv.BaseDiv4));
$display($psprintf("----------------------------------"));
endfunction: post_randomize
endclass: base_cfg
class base_cov;
covergroup base_cg (string name, ref base_cfg p_base_cfg);
option.per_instance = 1;
option.name = name;
option.comment = $sformatf("covergroup for covering ccr clocks");
BaseVal_cp: coverpoint p_base_cfg.BaseVal {
bins valid[] = { 1600, 1400, 1200, 1000, 800 };
bins default_val = default;
BaseDiv1_cp: coverpoint p_base_cfg.s_basediv.BaseDiv1 {
bins valid[] = {[0:3]};
BaseDiv2_cp: coverpoint p_base_cfg.s_basediv.BaseDiv2 {
bins valid_1600_0[] = {[0:7]} with ( (item inside {[0:7]}) ) iff (p_base_cfg.BaseVal == 1600 && p_base_cfg.s_basediv.BaseDiv1 == 0);
bins valid_1600_1[] = {[0:7]} with ( (item inside {[0:7]}) ) iff (p_base_cfg.BaseVal == 1600 && p_base_cfg.s_basediv.BaseDiv1 == 1);
bins valid_1600_2[] = {[0:7]} with ( (item inside {[0:3]}) ) iff (p_base_cfg.BaseVal == 1600 && p_base_cfg.s_basediv.BaseDiv1 == 2);
bins valid_1600_3[] = {[0:7]} with ( (item inside {[0:1]}) ) iff (p_base_cfg.BaseVal == 1600 && p_base_cfg.s_basediv.BaseDiv1 == 3);
bins valid_1400_0[] = {[0:7]} with ( (item inside {[0:7]}) ) iff (p_base_cfg.BaseVal == 1400 && p_base_cfg.s_basediv.BaseDiv1 == 0);
bins valid_1400_1[] = {[0:7]} with ( (item inside {[0:6]}) ) iff (p_base_cfg.BaseVal == 1400 && p_base_cfg.s_basediv.BaseDiv1 == 1);
bins valid_1400_2[] = {[0:7]} with ( (item inside {[0:2]}) ) iff (p_base_cfg.BaseVal == 1400 && p_base_cfg.s_basediv.BaseDiv1 == 2);
bins valid_1400_3[] = {[0:7]} with ( (item inside {[0:6]}) ) iff (p_base_cfg.BaseVal == 1400 && p_base_cfg.s_basediv.BaseDiv1 == 3);
bins valid_1200_0[] = {[0:7]} with ( (item inside {[0:7]}) ) iff (p_base_cfg.BaseVal == 1200 && p_base_cfg.s_basediv.BaseDiv1 == 0);
bins valid_1200_1[] = {[0:7]} with ( (item inside {[0:5]}) ) iff (p_base_cfg.BaseVal == 1200 && p_base_cfg.s_basediv.BaseDiv1 == 1);
bins valid_1200_2[] = {[0:7]} with ( (item inside {[0:2]}) ) iff (p_base_cfg.BaseVal == 1200 && p_base_cfg.s_basediv.BaseDiv1 == 2);
bins valid_1000_0[] = {[0:7]} with ( (item inside {[0:7]}) ) iff (p_base_cfg.BaseVal == 1000 && p_base_cfg.s_basediv.BaseDiv1 == 0);
bins valid_1000_1[] = {[0:7]} with ( (item inside {[0:4]}) ) iff (p_base_cfg.BaseVal == 1000 && p_base_cfg.s_basediv.BaseDiv1 == 1);
bins valid_1000_2[] = {[0:7]} with ( (item inside {[0:1]}) ) iff (p_base_cfg.BaseVal == 1000 && p_base_cfg.s_basediv.BaseDiv1 == 2);
bins valid_800_0[] = {[0:7]} with ( (item inside {[0:7]}) ) iff (p_base_cfg.BaseVal == 800 && p_base_cfg.s_basediv.BaseDiv1 == 0);
bins valid_800_1[] = {[0:7]} with ( (item inside {[0:3]}) ) iff (p_base_cfg.BaseVal == 800 && p_base_cfg.s_basediv.BaseDiv1 == 1);
bins valid_800_2[] = {[0:7]} with ( (item inside {[0:1]}) ) iff (p_base_cfg.BaseVal == 800 && p_base_cfg.s_basediv.BaseDiv1 == 2);
illegal_bins invalid_1600_2 = {[0:7]} with ( (item inside {[4:7]}) ) iff (p_base_cfg.BaseVal == 1600 && p_base_cfg.s_basediv.BaseDiv1 == 2);
illegal_bins invalid_1600_3 = {[0:7]} with ( (item inside {[2:7]}) ) iff (p_base_cfg.BaseVal == 1600 && p_base_cfg.s_basediv.BaseDiv1 == 3);
illegal_bins invalid_1400_1 = {[0:7]} with ( (item inside {[7:7]}) ) iff (p_base_cfg.BaseVal == 1400 && p_base_cfg.s_basediv.BaseDiv1 == 1);
illegal_bins invalid_1400_2 = {[0:7]} with ( (item inside {[3:7]}) ) iff (p_base_cfg.BaseVal == 1400 && p_base_cfg.s_basediv.BaseDiv1 == 2);
illegal_bins invalid_1400_3 = {[0:7]} with ( (item inside {[7:7]}) ) iff (p_base_cfg.BaseVal == 1400 && p_base_cfg.s_basediv.BaseDiv1 == 3);
illegal_bins invalid_1200_1 = {[0:7]} with ( (item inside {[6:7]}) ) iff (p_base_cfg.BaseVal == 1200 && p_base_cfg.s_basediv.BaseDiv1 == 1);
illegal_bins invalid_1200_2 = {[0:7]} with ( (item inside {[3:7]}) ) iff (p_base_cfg.BaseVal == 1200 && p_base_cfg.s_basediv.BaseDiv1 == 2);
illegal_bins invalid_1200_3 = {[0:7]} with ( (item inside {[0:7]}) ) iff (p_base_cfg.BaseVal == 1200 && p_base_cfg.s_basediv.BaseDiv1 == 3);
illegal_bins invalid_1000_1 = {[0:7]} with ( (item inside {[5:7]}) ) iff (p_base_cfg.BaseVal == 1000 && p_base_cfg.s_basediv.BaseDiv1 == 1);
illegal_bins invalid_1000_2 = {[0:7]} with ( (item inside {[2:7]}) ) iff (p_base_cfg.BaseVal == 1000 && p_base_cfg.s_basediv.BaseDiv1 == 2);
illegal_bins invalid_1000_3 = {[0:7]} with ( (item inside {[0:7]}) ) iff (p_base_cfg.BaseVal == 1000 && p_base_cfg.s_basediv.BaseDiv1 == 3);
illegal_bins invalid_800_1 = {[0:7]} with ( (item inside {[4:7]}) ) iff (p_base_cfg.BaseVal == 800 && p_base_cfg.s_basediv.BaseDiv1 == 1);
illegal_bins invalid_800_2 = {[0:7]} with ( (item inside {[2:7]}) ) iff (p_base_cfg.BaseVal == 800 && p_base_cfg.s_basediv.BaseDiv1 == 2);
illegal_bins invalid_800_3 = {[0:7]} with ( (item inside {[0:7]}) ) iff (p_base_cfg.BaseVal == 800 && p_base_cfg.s_basediv.BaseDiv1 == 3);
BaseDiv3_cp: coverpoint p_base_cfg.s_basediv.BaseDiv3 {
bins valid_1600_0[] = {[0:1]} with ( (item inside {[0:1]}) ) iff (p_base_cfg.BaseVal == 1600 && p_base_cfg.s_basediv.BaseDiv1 == 0);
bins valid_1600_1[] = {[0:1]} with ( (item inside {[0:1]}) ) iff (p_base_cfg.BaseVal == 1600 && p_base_cfg.s_basediv.BaseDiv1 == 1);
bins valid_1600_2[] = {[0:1]} with ( (item inside {[0:1]}) ) iff (p_base_cfg.BaseVal == 1600 && p_base_cfg.s_basediv.BaseDiv1 == 2);
bins valid_1600_3[] = {[0:1]} with ( (item inside {[0:0]}) ) iff (p_base_cfg.BaseVal == 1600 && p_base_cfg.s_basediv.BaseDiv1 == 3);
bins valid_1400_0[] = {[0:1]} with ( (item inside {[0:1]}) ) iff (p_base_cfg.BaseVal == 1400 && p_base_cfg.s_basediv.BaseDiv1 == 0);
bins valid_1400_1[] = {[0:1]} with ( (item inside {[0:1]}) ) iff (p_base_cfg.BaseVal == 1400 && p_base_cfg.s_basediv.BaseDiv1 == 1);
bins valid_1400_2[] = {[0:1]} with ( (item inside {[0:1]}) ) iff (p_base_cfg.BaseVal == 1400 && p_base_cfg.s_basediv.BaseDiv1 == 2);
bins valid_1200_0[] = {[0:1]} with ( (item inside {[0:1]}) ) iff (p_base_cfg.BaseVal == 1200 && p_base_cfg.s_basediv.BaseDiv1 == 0);
bins valid_1200_1[] = {[0:1]} with ( (item inside {[0:1]}) ) iff (p_base_cfg.BaseVal == 1200 && p_base_cfg.s_basediv.BaseDiv1 == 1);
bins valid_1200_2[] = {[0:1]} with ( (item inside {[0:1]}) ) iff (p_base_cfg.BaseVal == 1200 && p_base_cfg.s_basediv.BaseDiv1 == 2);
bins valid_1000_0[] = {[0:1]} with ( (item inside {[0:1]}) ) iff (p_base_cfg.BaseVal == 1000 && p_base_cfg.s_basediv.BaseDiv1 == 0);
bins valid_1000_1[] = {[0:1]} with ( (item inside {[0:1]}) ) iff (p_base_cfg.BaseVal == 1000 && p_base_cfg.s_basediv.BaseDiv1 == 1);
bins valid_1000_2[] = {[0:1]} with ( (item inside {[0:0]}) ) iff (p_base_cfg.BaseVal == 1000 && p_base_cfg.s_basediv.BaseDiv1 == 2);
bins valid_800_0[] = {[0:1]} with ( (item inside {[0:1]}) ) iff (p_base_cfg.BaseVal == 800 && p_base_cfg.s_basediv.BaseDiv1 == 0);
bins valid_800_1[] = {[0:1]} with ( (item inside {[0:1]}) ) iff (p_base_cfg.BaseVal == 800 && p_base_cfg.s_basediv.BaseDiv1 == 1);
bins valid_800_2[] = {[0:1]} with ( (item inside {[0:0]}) ) iff (p_base_cfg.BaseVal == 800 && p_base_cfg.s_basediv.BaseDiv1 == 2);
illegal_bins invalid_1600_0 = {[0:1]} with ( (item inside {[1:1]}) ) iff (p_base_cfg.BaseVal == 1600 && p_base_cfg.s_basediv.BaseDiv1 == 3);
illegal_bins invalid_1400_1 = {[0:1]} with ( (item inside {[0:1]}) ) iff (p_base_cfg.BaseVal == 1400 && p_base_cfg.s_basediv.BaseDiv1 == 3);
illegal_bins invalid_1200_2 = {[0:1]} with ( (item inside {[0:1]}) ) iff (p_base_cfg.BaseVal == 1200 && p_base_cfg.s_basediv.BaseDiv1 == 3);
illegal_bins invalid_1000_2 = {[0:1]} with ( (item inside {[1:1]}) ) iff (p_base_cfg.BaseVal == 1000 && p_base_cfg.s_basediv.BaseDiv1 == 2);
illegal_bins invalid_1000_3 = {[0:1]} with ( (item inside {[0:1]}) ) iff (p_base_cfg.BaseVal == 1000 && p_base_cfg.s_basediv.BaseDiv1 == 3);
illegal_bins invalid_800_2 = {[0:1]} with ( (item inside {[1:1]}) ) iff (p_base_cfg.BaseVal == 800 && p_base_cfg.s_basediv.BaseDiv1 == 2);
illegal_bins invalid_800_3 = {[0:1]} with ( (item inside {[0:1]}) ) iff (p_base_cfg.BaseVal == 800 && p_base_cfg.s_basediv.BaseDiv1 == 3);
BaseDiv4_cp: coverpoint p_base_cfg.s_basediv.BaseDiv4 {
bins valid_1600_0[] = {[0:1]} with ( (item inside {[1:1]}) ) iff (p_base_cfg.BaseVal == 1600 && p_base_cfg.s_basediv.BaseDiv1 == 0);
bins valid_1600_3[] = {[0:1]} with ( (item inside {[0:1]}) ) iff (p_base_cfg.BaseVal == 1600 && p_base_cfg.s_basediv.BaseDiv1 == 3);
bins valid_1400_0[] = {[0:1]} with ( (item inside {[1:1]}) ) iff (p_base_cfg.BaseVal == 1400 && p_base_cfg.s_basediv.BaseDiv1 == 0);
bins valid_1400_3[] = {[0:1]} with ( (item inside {[0:0]}) ) iff (p_base_cfg.BaseVal == 1400 && p_base_cfg.s_basediv.BaseDiv1 == 3);
bins valid_1200_0[] = {[0:1]} with ( (item inside {[1:1]}) ) iff (p_base_cfg.BaseVal == 1200 && p_base_cfg.s_basediv.BaseDiv1 == 0);
bins valid_1200_3[] = {[0:1]} with ( (item inside {[0:0]}) ) iff (p_base_cfg.BaseVal == 1200 && p_base_cfg.s_basediv.BaseDiv1 == 3);
bins valid_1000_0[] = {[0:1]} with ( (item inside {[1:1]}) ) iff (p_base_cfg.BaseVal == 1000 && p_base_cfg.s_basediv.BaseDiv1 == 0);
bins valid_1000_2[] = {[0:1]} with ( (item inside {[0:1]}) ) iff (p_base_cfg.BaseVal == 1000 && p_base_cfg.s_basediv.BaseDiv1 == 2);
bins valid_1000_3[] = {[0:1]} with ( (item inside {[0:0]}) ) iff (p_base_cfg.BaseVal == 1000 && p_base_cfg.s_basediv.BaseDiv1 == 3);
bins valid_800_2[] = {[0:1]} with ( (item inside {[0:1]}) ) iff (p_base_cfg.BaseVal == 800 && p_base_cfg.s_basediv.BaseDiv1 == 2);
bins valid_800_3[] = {[0:1]} with ( (item inside {[0:0]}) ) iff (p_base_cfg.BaseVal == 800 && p_base_cfg.s_basediv.BaseDiv1 == 3);
illegal_bins invalid_1600_0 = {[0:0]} iff (p_base_cfg.BaseVal == 1600 && p_base_cfg.s_basediv.BaseDiv1 == 0);
illegal_bins invalid_1400_3 = {[1:1]} iff (p_base_cfg.BaseVal == 1400 && p_base_cfg.s_basediv.BaseDiv1 == 3);
illegal_bins invalid_1200_0 = {[0:0]} iff (p_base_cfg.BaseVal == 1200 && p_base_cfg.s_basediv.BaseDiv1 == 0);
illegal_bins invalid_1200_3 = {[1:1]} iff (p_base_cfg.BaseVal == 1200 && p_base_cfg.s_basediv.BaseDiv1 == 3);
illegal_bins invalid_1000_0 = {[0:0]} iff (p_base_cfg.BaseVal == 1000 && p_base_cfg.s_basediv.BaseDiv1 == 0);
illegal_bins invalid_1000_3 = {[1:1]} iff (p_base_cfg.BaseVal == 1000 && p_base_cfg.s_basediv.BaseDiv1 == 3);
illegal_bins invalid_800_3 = {[1:1]} iff (p_base_cfg.BaseVal == 800 && p_base_cfg.s_basediv.BaseDiv1 == 3);
endgroup: base_cg
function new (ref base_cfg base_cfg_h);
base_cg = new($sformatf("base_cg"), base_cfg_h);
endfunction: new
endclass: base_cov
class base_env;
rand base_cfg m_base_cfg;
base_cov m_base_cov;
function new ();
m_base_cfg = new();
m_base_cov = new(m_base_cfg);
endfunction: new
endclass: base_env
base_env env;
int count;
env = new();
for (int i=0; i<4; i++) begin
for (int j=0; j<8; j++) begin
$display("\n\ncount = %0d, i = %0d, j = %0d", count, i, j);
$display($psprintf(".................................."));
if (!env.randomize() with {m_base_cfg.s_basediv.BaseDiv1 == i;}) begin
$error("env.randomize() with {m_base_cfg.s_basediv.BaseDiv1 == %0d;}", i);
#1;
env.m_base_cov.base_cg.sample();
#1;
count ++;
endmodule: top
