How do you compare negative integers in systemVerilog?
Here is a very simple dummy function, where I am trying to check is -1 is less than -2. -2 should be a smaller number, but does not seem that is whats happening in this function. Can someone explain to be what is going on here?
module tb;
  function dummy_function();
      int temp = -1;
      if(temp < -2) begin
        $display("Temp (%0d) is smaller than -2", temp);
      end else begin
        $display("Temp (%0d) is larger than or equal to -2", temp);
    dummy_function();
I’m not sure what you think is a problem. The expression (-1 < -2) should be false because -1 is greater than -2.
I agree, but the console output is still printing this:
If I do the following, it works as expected. It seems like the -2 is not treated as a signed number unless its explicitly stored in an int? I dont quite understand whats happening here
module tb;
      int temp = -1;
      int max = -2;
      if(temp < max) begin
        $display("Temp (%0d) is smaller than (%d)", temp, -2);
      end else begin
    dummy_function();
You have run into a tool bug. iverilog support of SystemVerilog is not very good. If you change the declaration of temp to integer, you get the correct result.
Okay, thank you for the tip!
