// A caveat on the use of that **throughout**
// The construct exp throughout seq is an abbreviation for the following:
(exp) [*0:$] intersect seq
// Your requirements: Once valid goes high on any channel, valid to be high
// while ready is low. You did not specify what the value of valid is when ready==1.
// The valid throughout ready[->1];
// means that when ready==1, valid==1
// If you need to specify that valid==0 when ready==1
// then you need to use the intersect of 2 sequences.
$rose(valid) |-> valid throughout ready[->1]);
ap_i1: assert property(@ (posedge clk) $rose(valid) |-> !valid[->1] intersect ready[->1]);
ap_thru1: assert property(@ (posedge clk) $rose(valid) |-> valid throughout ready[->1]);
http://SystemVerilog.us/vf/thruo_intersect.sv // testbench
http://SystemVerilog.us/vf/intersect.png // simulation
For training, consulting, services: contact http://cvcblr.com/home
https://verificationacademy.com/news/verification-horizons-march-2018-issue - SVA: Package for dynamic and range delays and repeats - SystemVerilog - Verification Academy
