In reply to irshad_mansur123:
Below is the simplest approach. The paper shows how you could use bind to insert many of these if the concrete class needs to go in many places in the hierarchy.
package test;
import uvm_pkg::*;
`include "uvm_macros.svh"
interface class backdoor_api;
pure virtual function void do_backdoor_wr();
// pure virtual function void do_backdoor_rd();
class test extends uvm_test;
`uvm_component_utils(test)
backdoor_api api_h;
super.new(name,parent);
if (!uvm_config_db#(backdoor_api)::get(this,"","api",api_h))
`uvm_fatal("NOAPI","API handle not set")
api_h.do_backdoor_wr();
endpackage
module testbench_top;
import test::backdoor_api;
import uvm_pkg::*;
class concrete extends uvm_object implements backdoor_api;
function new(string name);
super.new(name);
top.dut.block_a.mem.do_backdoor_wr();
concrete api_h = new("api_h");
uvm_config_db#(backdoor_api)::set(null,"*","api",api_h);
run_test("test");
module top;
dut dut();
module dut;
block block_a();
module block;
memory mem();
module memory;
$display("%m doing backdoor write");
