I am trying to randomize an address and make sure that address has not been selected before. I have a few other constraints as well. Here is an example of what I am doing:
random_reg_addr = new[32];
random_reg_data = new[32];
foreach(random_reg_addr[pkt_idx]) begin
// randomize register address
if (!std::randomize(random_reg_addr[pkt_idx]) with {
random_reg_addr[pkt_idx] inside {[24'h0:24'hFFFFFF]};
(random_reg_addr[pkt_idx] % 4) == 0; // 4 byte alligned
}) begin
`uvm_fatal(get_name(), $sformatf("Failed to randomize reg address"))
How can I make it so that each address is unique. I keep trying and my implementation of it causes the randomization to fail.
Randomize the entire array as an aggregate and put the foreach loop inside the constraint. Here is a complete example
bit [23:0] random_reg_addr[] = new[32];
if (!std::randomize(random_reg_addr) with {
foreach(random_reg_addr[pkt_idx]) {
random_reg_addr[pkt_idx] inside {[24'h0:24'hFF]};
random_reg_addr[pkt_idx] % 4 == 0; // 4 byte alligned
unique {random_reg_addr};
$fatal("Failed to randomize reg address");
$displayh(random_reg_addr[pkt_idx]);
This worked great, thanks. But now I am wondering how I can make sure each address is spaced far enough away from each other in the case that I am writing a burst of size x, I want to prevent them for overlapping and overwriting previous data during the test. I have a queue of all the random sizes for each packet. I am just wondering how would I check this within the foreach loop inside std::randomize
